Dilution: 18-2wt% Solution | Calculate Volume
  • Thread starter Thread starter flatpro
    Dilution
To dilute an 18 wt% solution to a 2 wt% solution, the initial concentration (C1) is 18% and the final desired concentration (C2) is 2%. The user aims for a final volume of 10 ml, leading to the equation (180 mg/ml)(X) = (2 mg/ml)(10 ml). After calculations, the user finds X to be 0.11 ml, which raises concerns about the accuracy of the dilution. Clarification is needed on whether 2 mg/ml corresponds to 2 wt%, as this may be causing confusion in the calculations.
flatpro
Hey,
I have a solution of 18 wt % (about 1g/ml) I want to make it into a solution of 2 wt % by diluting it with water. Using C1 V1 = C2 V2 could someone show me how to do it. I have tried but seem to be getting muddled somewhere.
Thanks!
You need to know (or assume) initial (or final) volume.
Show what you did, we will start from there.
Final desired volume 10ml
18% of 1g = 180mgC1 V1 = C2 V2
(180mg/ml)(X) = (2mg/ml) (10ml)
X = 2 (10) / 189
X = 0.11 ml <--- which seems too low
Why 2 mg/mL?
I mean 2 wt percentage of the final solution
Perhaps that's what you mean, but does 2 mg/mL equal 2%?
methods
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
