Dimension of a topological space
The discussion centers on the definition of dimension in topological spaces as presented in Hartshorne's book. It establishes that the dimension of a topological space, denoted as dim(X), is the supremum of integers n such that there exists a chain of distinct irreducible closed subsets. The participants clarify that the empty set is not considered irreducible, and the definition of irreducibility must be adapted for topological spaces. The conversation also highlights the complexity of defining dimension across different contexts, such as algebraic varieties and topological spaces.
  • Understanding of topological spaces and their properties
  • Familiarity with irreducible closed subsets in topology
  • Knowledge of algebraic varieties and their dimensions
  • Basic concepts of the Zariski topology
  • Research the definition and properties of irreducible closed subsets in topology
  • Explore the concept of Krull Dimension in algebraic geometry
  • Study various definitions of dimension for topological spaces
  • Investigate the implications of the Zariski topology on algebraic varieties
Mathematicians, particularly those specializing in topology and algebraic geometry, as well as students seeking to understand the nuances of dimension in various mathematical contexts.
matness
In Hartshorne's book definition of a dimension is given as follows:
İf X is a t.s. , dim(X) is the supremum of the integers n s.t. there exist a chain
Z_0 \subsetneq Z_1...\subsetneq Z_n
of distinct irreducible closed subsets of X
My question is:
Can we conclude directly that any topological space has dim greater than or equal to 1, since empty set and and X itself is always closed?
Example in the same book says no in a way.It says A^1 has dim 1.
Although \emptyset \subsetneq {any point} \subsetneq X
Should I exclude empty set ?
What is your definition of "irreducible closed subset"?
yes.that is the answer.i was careless as always.
another question then: can we say empty set is reducible then. since it is not irreducible
Or do we exclude this set from the discussion of reducibility/irreducibility?
(my guess is second choice is less problematic)
This is one definition for dimension of algebraic varieties. There are several others...such as the Krull Dimension of the variety's associated coordinate ring.
The empty set an irreducible algebraic variety. Irreducibility of an algebraic variety V means that if V=W_1 union W_2, then W_1=empty set or W_2=empty set.
I believe that the definition of dimension that you provide does generalize to topology but as you have already mentioned you have to determine what it means to be irreducible. But, yeah you either have to throw out the overall space or the empty set.
You still haven't answered my question: what is the definition of irreducible closed subset? And, since you mention it, what is the definition reducible closed subset?
Irreducibility is a property of algebraic varieties. I will post what I put in my previous post again:
Irreducibility of an algebraic variety V means that if V=W_1 union W_2, then W_1=empty set or W_2=empty set.There may be other equivalent ways of saying it.
The way to talk about the situation for topological spaces is much more complicated. You need something analogous to closed balls in R^n. I.e., closed sets whose boundary has dimension 1 less than the closed set. Then the next closed ball is going to be contained in the other boundary.
Hartshorne's definition of "irreducibile" and "dimension" are for arbitrary topoplogical spces. matness stated the definition of "dimension" correctly. (He has not yet stated Hartshorne's definition of "irreducible")
Yes, there are several other ways to define the notion of "dimension" for topological spaces -- but those other ways are not the ones Hartshorne is using in his text.
ah, I see:
irreducibility for a topological space must then be taking the definition I provided above except changing the words "algebraic set" to be closed set.
eastside00_99 said:
ah, I see:
Effectively; the exception is that, in Hartshorne, the empty set is defined to be not irreducible.
For (traditional) varieties, of course, they're the same thing: the closed sets in the Zariski topology are precisely the algebraic sets. Much of Hartshorne works with schemes (a generalization of varieties) but he states these topological definitions in full generality (and they might be relevant in the sections where he talks about ringed spaces).
Well, I don't see the problem with letting the empty set be considered a scheme. We trivially have a sheaf of modules associate with {} and we trivially have the empty topology ({},{{}}). But, yeah, if you are going to work with schemes using topological definitions makes sense.
A 'nonempty' subset of a topological space is irreducible if it can not be written as union of its two proper closed subsets.
Because of the word 'nonempty' the argument in my first post is useless. And while writing second post i took definition of reducible as not being irreducible
Although I can not see directly( or indirectly) , they should be equivalent to be consistent in topology, arent they?
There's nothing wrong with having several different notions of dimension.
Probably the most obvious example of this is that sometimes we want to consider C as a two-dimensional space, and sometimes as a one-dimensional space.
(Hartshorne's definition is usually only useful for Noetherian spaces -- according to it, C is infinite dimensional. But C with the Zariski topology is 1-dimensional)
I just discovered this thread where the topological dimension is playing a role. I am interested in this question:
Let {\mathbb I} = {\mathbb R} \setminus {\mathbb Q} the set of the irrational numbers of the real line.
What is the topological dimension of
{\mathbb R}^2 \setminus {\mathbb I} \times {\mathbb I} ?
you just have to take the right notion of subspaces. dimension of an algebraic variety is the length of a maximal nested seqeunce of irreducible algebraic subvarieties.
the dimension of a linear space is the length of a maximal sequence of linear subspaces.
so the (linear) dimension of C is the maximal length of a sequence of linear subspaces of C, hence the real linear dimension is 2 and the complex linear dimension is 1.
  • · Replies 25 ·
