Is the API Hydrocarbon Emission Formula Dimensionally Consistent?
The discussion centers on the dimensional consistency of the hydrocarbon emission formula provided by the American Petroleum Institute. Concerns are raised about the term (p/(14.7-p))^0.68, questioning whether it is dimensionless due to the presence of atmospheric pressure. Participants note that formulas often require specific units for accurate application and that constants in formulas typically have no units. The distinction between equations and formulas is emphasized, highlighting the importance of unit consistency when interpreting results. Overall, the conversation underscores the need for careful consideration of units in scientific formulas.
popoff
The American Petroleum Institute has published a correlation for determining the hydrocarbon emissions from fixed-roof storage tanks
Ly = (24/1000) * (p/(14.7-p))^0.68 * D^1.73 * H^0.51 * T^0.5 * Fp * C
where: Ly is breathing emissions, bbl/yr; p is the true vapor pressure at the bulk temperature, psia; D is the tank diameter, ft; H is the height in ft; T is the average tank outage corrected for roof volume, ft; Fp is the dimensionless paint factor; and C is the dimensionless adjustment factor.
Is this equation dimensionally consistent?
Unit conversions
I have a doubt with the (p/(14.7-p))^0.68 term. I think it should be dimensionless, but I am not totally sure as there is a 14.7 with no units minus a pressure in psia...
Likes ayeshanaved23
popoff said:
... as there is a 14.7 with no units minus a pressure in psia...
What is atmospheric pressure in psi?
It's terms like that that indicate that this is not an equation, but a formula. There are many such formulas for different disciplines, typically compiled into handbooks, where you must enter the variable values as dimensionless magnitudes of quantities that are given in specific units. A formula is "true" only so long as you specify all quantities in the required units and don't entry the units :smile:
A formula's constants typically have no units so you can't trivially "translate" the formula to work with other units, and since you have to interpret the result of the formula in particular units you can't just treat the expression as an equation and "solve" for any of the variables in terms of the others without putting some thought into what you're doing.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
