What Is Dimensional Regularization in Arbitrary Dimensions?
  • Thread starter Thread starter ice109
    Regularization
Dimensional regularization is a technique used to handle divergent integrals by extending the number of dimensions in which the integral is evaluated. The integral presented, involving a vector quantity \(\ell\) and a constant \(\Delta\), diverges in four dimensions but can be expressed in arbitrary dimensions \(D\). As \(D\) approaches 4, the integral's behavior reveals a logarithmic divergence, which is analyzed through limits. The beta function \(B\) and the gamma function \(\Gamma\) play crucial roles in this process, providing a framework for evaluating the integral. Understanding the implications of arbitrary dimensions and the mathematical tools involved is essential for grasping the underlying concepts of dimensional regularization.
ice109
i'm doing an integral for my advisor that is way beyond me but i have pages from a textbook that tell me how to do it so here goes
\int\frac{d^4\ell}{(2\pi)^4}\frac{1}{(\ell^2+A^2)^2} = \frac{1}{2}B(0,2)
which is divergent
but in arbitrary dimensions
you get
\int\frac{d^4\ell}{(2\pi)^4}\frac{1}{(\ell^2+A^2)^2} = \frac{1}{(4\pi)^\frac{D}{2}}\frac{\Gamma (2-\frac{D}{2})}{\Gamma (2)}(\frac{1}{A})^{2-\frac{D}{2}}
and setting \epsilon = 4-D
and then letting D approach 4 we get
\frac{1}{(4\pi)^{2}}(\frac{2}{\epsilon}-log\Delta - \gamma +log(4\pi) + O(\epsilon))
where
\gamma \approx .5772
the thing is i only understand why this works on a very very superficial level. something along the lines of taking a limit and studying behavior as the limit approaches a "pole." but i really have no intuitive clue as to what an integral in arbitrary space even means. can anyone give me some sense of what's going on.
Mathematics news on Phys.org
anybody? anybody? maybe this should be moved into atomic physics
4 dimensional calculus is the same as 3 dimensional calculus, except for the extra dimension.
You appear to be leaving out some details. I imagine that l is supposed to be a vector quantity, and that you have some particular regions of integration in mind that you haven't shared with us.
I don't know what "arbitrary dimensions" means, or from where D and \Delta came. The meaning of B is not obvious to me from the context either.
LaTeX tip: use \left( and \right) to make large parentheses. (You can replace parentheses with other symbols too)
ahh I've made lots of mistakes in the write up
\int\frac{d^D\ell}{(2\pi)^D}\frac{1}{(\ell^2+\Delta)^ 2} = \frac{1}{(4\pi)^\frac{D}{2}}\frac{\Gamma (2-\frac{D}{2})}{\Gamma (2)}\left(\frac{1}{\Delta}\right)^{2-\frac{D}{2}}
region of integration is all of space. yes \ell is a vector,arbitrary dimensions means just that, instead of 3 or 4 , D and it comes from how to solve that integral.
\Delta is just a constant and B is the beta function.
don't mind this stuff, something i started typing out before i realized my initial write up was completely retarded. if you need to know how to work out the integral i'll finish that up.
\int\frac{d^D\ell}{(2\pi)^D}\frac{1}{(\ell^2+\Delta)^ 2} = \int\frac{d\Omega_{D}}{(2\pi^D)}}\int^{0}_{\infty}d\ell\frac{\ell^{D-1}}{(\ell^2+\Delta)^2}= \frac{2(\sqrt{\pi})^D}{\Gamma(\frac{D}{2})}\left(
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
