Dimensionless Radial Equation Hydrogen Atom
The discussion focuses on deriving the dimensionless radial equation for the hydrogen atom, expressed in terms of the variable ξ. The radial equation is reformulated to show the relationship between the effective mass μ and the potential energy U(r). Participants clarify that μ is the reduced mass, which accounts for the motion of two particles, such as the electron and proton in a hydrogen atom. The effective mass is approximated to be equal to the electron mass due to the significant mass difference between the proton and electron. The thread highlights the importance of understanding the integration with respect to ξ and the role of μ in simplifying the radial equation.
Summer95
Show that in terms of the dimensionless variable ##\xi## the radial equation becomes ##\frac{\mathrm{d}^{2} u}{\mathrm{d} \xi^{2}}=(\frac{l(l+1)}{\xi^{2}}-\frac{2}{\xi}-K)u##
##u(r)\equiv rR(r)##
##\xi \equiv \sqrt{2\mu U_{0}}\frac{r}{\hbar}## dimensionless variable
##K\equiv \frac{E}{U_{0}}##
Radial equation: ##-\frac{\hbar^{2}}{2\mu}\frac{1}{r^{2}}\frac{\mathrm{d} }{\mathrm{d} r}(r^{2}\frac{\mathrm{d} }{\mathrm{d} r}R)+\frac{\hbar^{2}l(l+1)}{2\mu r^{2}}R+U(r)R=ER##
and ##U(r)## is the coulomb potential
The radial equation becomes:
##-\frac{U_{0}}{\xi^{2}}\frac{\mathrm{d} }{\mathrm{d} r}(r^{2}\frac{\mathrm{d} }{\mathrm{d} r}\frac{u}{r})+\frac{U_{0}l(l+1)}{\xi^{2}}\frac{u}{r}+U(r)\frac{u}{r}=E\frac{u}{r}##
and after taking the derivatives and some canceling:
##-\frac{r}{\xi^{2}}\frac{\mathrm{d}^{2}}{\mathrm{d}r^{2}}u+\frac{l(l+1)}{\xi^{2}}\frac{u}{r}+\frac{U(r)}{U_{0}}\frac{u}{r}=K\frac{u}{r}##
and so
##\frac{r^{2}}{\xi^{2}}\frac{\mathrm{d}^{2} }{\mathrm{d} r^{2}}u=(-K+\frac{l(l+1)}{\xi^{2}}-\frac{e^{2}}{4\pi \varepsilon _{0}rU_{0}})u##
so two of the terms on the right are fine. I then substituted the ground state of hydrogen in for ##U_{0}## in the last term, and the only way that comes out correctly is if ##\mu## (the effective mass) ##=16m##. Is this the case? I don't really understand how ##\mu## is defined. and I don't understand how to integrate with respect to ##\xi## in the first term. Thank you so much in advance!
edit: actually, not sure where I got the extra factor of 4 in there but ##\mu=m## what is the point of defining ##\mu##?
μ is the reduced mass:
\mu = \frac{m_1 m_2}{m_1+m_2}
It appears when one separates the center-of-mass motion (which depends on the total mass) from the relative motion (which depends on the reduced mass) for a system of two particles.
For a hydrogen atom, since the mass of the proton is 3 orders of magnitude bigger, one gets
\mu = \frac{m_e m_p}{m_e+m_p} \approx \frac{m_e m_p}{m_p} = m_e
Likes Summer95
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
