Diode Malfunction: 1N4007 Troubleshooting at 900V
  • Thread starter Thread starter Ravaner
    Diode
The discussion centers on the performance of 1N4007 diodes in a voltage multiplier circuit operating near 900V. Users report that some diodes fail despite appearing functional when tested with an ohmmeter, while others work well at lower voltages. The phenomenon is attributed to the diodes' leakage at high reverse voltages, which varies with temperature and individual diode characteristics. It is noted that as long as the diodes do not overheat, they should remain undamaged. Understanding these factors is crucial for troubleshooting diode performance in high-voltage applications.
Ravaner
Hello. I use 1N4007 diodes in a voltage multiplier near the maximum authorized 900 V (max reverse 1000 V). Some don't work and I replace them, but ... With an ohmeter they look correct and more using them with medium voltage ( 200 V ) they work perfectly. So they aren't destroyed, could someone explain me this phenomenon ?
All diodes are "Zener" diodes. They leak a little when the reverse voltage gets high enough. They won't be damaged as long as they don't get too hot. Also, the reverse voltage at which they leak depends on temperature, and certainly there'll be variation from one 1N4007 to another.
Thanks for your answer
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
