Calculating forces and torque on a moving dipole in non-uniform magnetic field
  • Thread starter Thread starter Gertrude
    Dipole Field
Gertrude
I want to determine the net force and torqe on a moving electric dipole in non-uniform magnetic field.
I suspect I should take some kind of a limit, but I'm not sure how to do so.
Please help, I'd really like to understand this.
##\mathbf{F} = q \mathbf{v} \times \mathbf{B}, \quad \mathbf{\tau} = \mathbf{r} \times \mathbf{F}, \quad \mathbf{p} = q \mathbf{d}##
I wrote the velocities as the average velocity ##\mathbf{v} = (\mathbf{v}_1+\mathbf{v}_2)/2## plus the difference (index 1 indicates the positive charge and 2 the negative charge):
$$\mathbf{F} = q\mathbf{v}_1 \times \mathbf{B}(\mathbf{r} + \mathbf{p}/q) - q\mathbf{v}_2 \times \mathbf{B}(\mathbf{r})$$
So what I got in the end was:
$$\mathbf{F} = q \mathbf{v} \times (\mathbf{B}(\mathbf{r} + \mathbf{p}/q) - \mathbf{B}(\mathbf{r})) + \frac{q}{2} \dot{\mathbf{p}} \times (\mathbf{B}(\mathbf{r} + \mathbf{p}/q) + \mathbf{B}(\mathbf{r}))$$
I'm stuck here and I'm not sure how to get a 'nicer' form that would only contain ##\mathbf{B}(\mathbf{r})##.
Regarding the torque:
$$\mathbf{\tau} = \frac{\mathbf{d}}{2} \times \mathbf{F}_1 - \frac{\mathbf{d}}{2} \times \mathbf{F}_2$$
Rearraging a bit I got:
$$\mathbf{\tau} = \frac{\mathbf{p}}{2} \times (\mathbf{v}_1 \times \mathbf{B}(\mathbf{r} + \mathbf{p}/q) + \mathbf{v}_2 \times \mathbf{B}(\mathbf{r}))$$
From here on I have the same problem as before.
If you can help me with a hint or two I'll be really grateful.
Hello Gertrude, :welcome:
Did you work out the case for the homogeneous ##\mathbf B## field already ?
An electric dipole generally has a small size ##\mathbf d## so I expect the derivative of ##\mathbf B## to appear for the non-homogeneous case (i.e. the limit ##\mathbf d \downarrow 0## seems useful to me.
I would also work with the center of the dipole, not with one of the charges as central point.
Likes Gertrude
Hello, thanks for answering!
As a matter of fact I did compute a net force and torque in uniform magnetic field before. I got:
$$ \mathbf{F} = \dot{\mathbf{p}} \times \mathbf{B}, \quad \mathbf{\tau} = \mathbf{p} \times (\mathbf{v}_C \times \mathbf{B})$$
with ##\mathbf{v}_C## being the velocity of the center of mass ##\mathbf{r}_C = (\mathbf{r}_1 + \mathbf{r}_2)/2##.
Now for the non-uniform case: I can see that in the first summand of the force, I get a derivative (in three dimensions, thus a gradient in the direction of orientation):
$$q \mathbf{v} \times (\mathbf{B}(\mathbf{r} + \mathbf{p}/q) - \mathbf{B}(\mathbf{r})) = q \mathbf{v} d \times \frac{(\mathbf{B}(\mathbf{r} + \mathbf{p}/q) - \mathbf{B}(\mathbf{r}))}{p/q} => p \mathbf{v} \times (\hat{\mathbf{d}} \cdot \nabla) \mathbf{B}(\mathbf{r})$$
and in the second summand I get:
$$\frac{q}{2} \dot{\mathbf{p}} \times (\mathbf{B}(\mathbf{r} + \mathbf{p}/q) + \mathbf{B}(\mathbf{r})) => q \dot{\mathbf{p}} \times \mathbf{B}(\mathbf{r})$$
I believe ##\mathbf{v}## is the translation velocity of the center of mass. By the way, is it mathematically correct to take such limits as I did (especially the second term, where I had a sum of the fields)?
So I see the force gets one extra term comparing to the uniform case, which seems logical.
In computing the torque I did something similar:
$$\frac{\mathbf{p}}{2} \times (\mathbf{v} \times (\mathbf{B}(\mathbf{r} + \mathbf{p}/q) + \mathbf{B}(\mathbf{r})) + \frac{\dot{\mathbf{p}}}{2q} \times (\mathbf{B}(\mathbf{r} + \mathbf{p}/q) - \mathbf{B}(\mathbf{r}))) =>$$
$$=> \frac{\mathbf{p}}{2} \times (2\mathbf{v} \times \mathbf{B}(\mathbf{r}) + \frac{d}{2q} \dot{\mathbf{p}} \times (\hat{\mathbf{d}} \cdot \nabla) \mathbf{B}(\mathbf{r}))$$
Since ##\dot{\mathbf{p}} = q(\mathbf{v}_1- \mathbf{v}_2)## only changes direction, it's always perpendicular on ##\hat{\mathbf{d}}## (and ##\mathbf{p}##) and thus the second term is zero.
So the torque is the same as in uniform case? I didn't expect that.
Am I on the right path of thinking?
I should think so (but haven't time to scrutinize all the steps).
Turns out someone did a lot of work already; perhaps this article is a nice starting point ... complicated enough already without inhomogeneity (and they work in gaussian units, too. That's reasonable but an extra complication nevertheless o_O ). Your ## \mathbf{\tau} = \mathbf{p} \times (\mathbf{v}_C \times \mathbf{B}))## looks like their (19a) .
I'll surely take a look at that, thank you for your time.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
