Couple of things: 1. you have a Greens Function issue -- for example, go for E=0. Then you have the equation for a Coulomb potential from a charge of magnitude aVoW(a), where W is the wave function (Coulomb potential). More generally, you are dealing with a linear spatial wave equation, the Helmholtz Eq. with a source at a. Now, instead of a 1/r solution, you'll get ingoing and outgoing spherical waves. Again, the strength of the source is proportional to the wave function at a.
2. In momentum space, the problem appears to be a bit easier, or at least, more transparent. In fact, the momentum space version gives Cooper's Eq. for Cooper Pairs -- for an attractive interaction, a resonance for a + potential. You can see this from the consistency requirement that arises when W(a) occurs on both sides of the equation.
To find the l=0, or S wave component, simply integrate the wave function over the solid angle. Why?
There's an enormous amount of physics in this equation, including the core of the BCS theory of superconductivity, and a spectacular example of the HUP in action.
Regards,
Reilly Atkinson
