Direction and magnitude of electric field produced by current change
  • Thread starter Thread starter songoku
The discussion revolves around the electric field produced by changing currents in a solenoid and the associated calculations. Participants question the absence of the cosine term in the induced emf calculation, clarifying that the angle does not affect the flux through a tightly wrapped sensing coil. There is also confusion regarding the number of turns of the solenoid in the electric field equation, with explanations highlighting the relationship between the magnetic field and turns per unit length. The conversation emphasizes the importance of understanding magnetic flux linkage and the correct application of Faraday's Law. Overall, the thread provides insights into the nuances of electromagnetic theory and calculations related to solenoids.
songoku
Please see below
Faraday Law
The answer key is:
a) ##\frac{\mu_o \pi nar_{1}^{2}}{R}##
b) ##-\frac{\mu_o abn}{2}##
My questions:
1) Why is there no ##\cos \theta## in answer (a)?
$$\text{induced current}=\frac{\varepsilon}{R}$$
When calculating induced emf ##\varepsilon=-\frac{d\Phi}{dt}=-\frac{d(\vec B . \vec A)}{dt}##, wouldn't the magnetic field produced by the solenoid making angle ##\theta## with respect to normal of plane of loop of wire so the rate of change of magnetic flux experienced by the loop is ##\mu_o an \pi r_{1}^{2} \cos \theta##?
2) Why is there no ##N## in answer (b), where ##N## is number of turns of the solenoid?
$$\int \vec E . d\vec s=-\frac{d\Phi}{dt}$$
##\Phi## is magnetic flux linkage so shouldn't ##\Phi=N\phi## so there is ##N## in the final answer?
3) Is the direction of electric field at distance ##b## in positive y direction?
Thanks
songoku said:
My questions:
1) Why is there no cos⁡θ in answer (a)?
Because whoever wrote the answer didn't put it in?
Clearly, if θ = 90°, there will be no changing flux through the loop and hence no induced current.
songoku said:
Why is there no N in answer (b), where N is number of turns of the solenoid?
Because the magnetic field inside a very long solenoid of ##N## turns and length ##L## is approximated as ##B=\mu_0 n I## where ##n=\dfrac{N}{L}## is the number of turns per unit length.
The induced current is the result of the magnetic flux that couples (i.e. flows through) the wire loops in the solenoid and the outer sensing coil. This is Faraday's Law. The solenoid flux in one direction is essentially entirely contained within the solenoid.
So if the sensing coil wraps around the solenoid (sort of tightly*) the angle doesn't matter, the flux through it will be the same.
An analogy is if you were counting cars on a freeway that pass through an imaginary plane, it wouldn't matter if that plane was tilted, as long as every car had to pass through it somewhere.
* You don't want that outer coil to capture much of the returning flux. A gigantic outer coil might not see any net flux, it could all (mostly) cancel.
I mean why for the flux it is not ##\frac{\mu_o N^2 I}{L}##. I saw something similar to this when calculating self inductance of solenoid; I need to multiply the flux to get total flux linkage so the self inductance can be ##\frac{\mu_o N^2 \pi r^2}{L}##
I understand
For electric field in question (b), the correct answer is ##-\frac{\mu_o abn}{2}## or ##-\frac{\mu_o abnN}{2}##?
Thanks
What is the expression for the magnetic field ##B## inside a solenoid?
What is the expression for the flux through the single loop in this problem?
Thanks
Since n=N/L, you are effectively asking whether it is ##-\frac{\mu_o abN}{2L}## or ##-\frac{\mu_o abN^2}{2L}##.
Perhaps you meant should it be ##-\frac{\mu_o abn}{2}## or ##-\frac{\mu_o abN}{2}##? If so, to put it another way, would the result be different if the solenoid were longer, but still the same winding density?
Well, what do you think?
Perhaps you meant should it be is ##-\frac{\mu_o abn}{2}## or ##-\frac{\mu_o abN}{2}##? If so, to put it another way, would the result be different if the solenoid were longer, but still the same winding density?
I am actually asking whether it is ##-\frac{\mu_o abN}{2L}## or ##-\frac{\mu_o abN^2}{2L}## but I think now I know why I am wrong.
I was mistaken when taking which object to consider. I thought I need to consider the number of turns of solenoid. It turns out I need to consider the loop.
Thank you very much for all the help and explanation kuruman, DaveE, haruspex
