Direction of Acceleration Vector
In circular motion, the direction of the acceleration vector is typically perpendicular to the motion, particularly in uniform circular motion. The centripetal force acts inward, causing this perpendicular acceleration. However, the question's wording could lead to confusion, as it does not specify uniform circular motion or distinguish between centripetal and net acceleration. Clarifying these terms would enhance understanding and accuracy in responses. Overall, the direction of the acceleration vector in circular motion is context-dependent.
laurenbaboran
What is true about the direction the acceleration vector points in circular motion situations?
a It is perpendicular to the motion.
b There is no acceleration.
c It points opposite the motion.
d It points parallel to the motion.
I got a, because if the object goes in a circle and the centripedal force pulls it it, it's perpendicular. Am I right?
Centripetal perhaps? And yes, you are correct.
Thank you so much :) Good to know about the spelling. You learn something new every day!
The direction of centripetal acceleration is perpendicular to the motion .But the question asks direction of acceleration vector which may or may not be perpendicular to the motion .The direction of net acceleration vector is perpendicular only in case of uniform circular motion.
The question should either specify that it is a uniform circular motion or should ask the direction of centripetal acceleration .Only then ,the options make sense.
