Direction of Axle Force on Pivoted Disk
The discussion revolves around the direction of the axle force on a pivoted disk, exploring concepts of forces in equilibrium, reaction forces, and the identification of force directions in various scenarios. Participants engage with theoretical aspects and practical examples related to mechanics.
  • Some participants question why the axle force is directed downward, suggesting that the upper part of the disk exerts a downward force due to gravity, which should result in an upward reaction force from the pivot according to Newton's third law.
  • One participant mentions specific force values, indicating that the axle force must balance the known forces acting on the disk.
  • There is a discussion about identifying the direction of forces, with one participant confirming that the axle force is a reaction force that must equal and oppose the resultant of all known forces.
  • Participants explore the concept of normal forces and their identification, with one expressing surprise that normal forces can be considered unknown in certain contexts.
  • Clarifications are made regarding the nature of reaction forces and how they can be resolved into components, with a focus on the distinction between normal and friction forces.
Participants express differing views on the nature and direction of forces, particularly the axle force and normal forces. There is no consensus on the interpretation of these forces, and the discussion remains unresolved regarding the specifics of force direction and identification.
Participants highlight the complexity of identifying forces in equilibrium and the potential for multiple reaction forces, indicating that additional information may be necessary to resolve certain problems.
LovePhys
Hello everyone,
I came across this problem from my Physics textbook.
I do not understand why the direction of the axle force is pointing downward. I think the upper part of the disk is exerting a downward force on the pivot (as it is pulled down by the Earth's gravity), and according to Newton's third law, the pivot should exert an upward force on the upper part of the disk?
Please correct if I am wrong, thank you very much!
LovePhys
Hello LovePhys! :smile:
The weight is about 50 N down, and the cable force is about 100 N up,
so the force from the axle has to be about 50 N down. :wink:
@tiny-tim:
Thank you for your reply.
I think I know what you mean. Do we generally identify the direction of all the forces and leave the axle force to the last?
Oh, and can you please have a look at this problem for me? It is the same kind of question. I don't understand why they say: "Because the plank is resting on the supports, not held down, forces n1 and n2 must point upward. The supports could pull down if the plank were nailed to them..."
Thank you very much indeed!
LovePhys
Hi LovePhys! :smile:
(just got up :zzz:)
Yes, that's exactly correct.
The axle force is a single reaction force, ie an unknown force, and so (in equilibrium) it must be equal and opposite to the resultant (the vector sum) of all the known forces.
(you're probably more familiar with the reaction force on body A from body B being equal and opposite to the reaction force on body B from body A, but it's also equal and opposite to all the other forces on body A, in equilibrium :wink:)
btw, it's the same with eg the normal force for an object being pulled along a slope … we find all the known forces, and then the normal force is calculated to balance them
(and also for the kinetic friction force for steady motion … kinetic friction is also an unknown force, since all we know is it's less than µN)
in 2D you can have 2 reaction forces, and find them this way (using moments), and in 3D you can have 3 reaction forces, and find them this way …
if you have more than 2 (or 3) reaction forces, the problem is indeterminate, and you can only solve it with extra information, about the bending properties of the object
… I don't understand why they say: "Because the plank is resting on the supports, not held down, forces n1 and n2 must point upward. The supports could pull down if the plank were nailed to them..."
They mean
i] as shown, the planks are not nailed, therefore the supports can't pull them down, therefore the reaction force must be either up or zero
ii] if the planks are nailed, then obviously the reaction force could be up zero or down
So if you add all the known forces, and the resultant is down, then in both cases the reaction force is up.
But if you add all the known forces, and the resultant is up, then in the second case the reaction force is down, but in the first case equilibrium is impossible and the plank will rise.
@tiny-tim:
Thank you, you have been so helpful. Btw, sorry for the late reply, I've been thinking about what you said to make sure that I do understand them! :biggrin: But still, I have a problem with this:
In Newtonian mechanics, I've never thought that the normal force could be an unknown force. Normally, I have a block moving up an incline or something like that, then the block is not in equilibrium as it's moving, and also I admit that I just draw the direction of the normal force intuitively based on the hint that it is "normal" to the contact surface.
(just got up :zzz:)
I'm not sure what your question is. :confused:
as to direction, the general term is "reaction force"
("normal" is simply another word for "perpendicular", from the latin word "norma" meaning a mason's set-square)
sometimes it is obvious that the reaction force is normal to the surface
but usually even the direction is unknown
in that case, we usually arbitrarily resolve the reaction force into two perpendicular components, which we call the normal force and the friction force …
but those two forces aren't really separate forces at all, and we only pretend they are for convenience
@tiny-tim: Your post has answered my question! I have learned something new, thanks a lot!
  • · Replies 18 ·
  • · Replies 51 ·
  • · Replies 16 ·
