Discharge-rods safety accessory
  • Thread starter Thread starter rabrave
    Safety
The discussion revolves around designing an electronic safety accessory for discharge rods that signals the success of a discharge process in high voltage laboratories. The device must operate safely at voltages up to one hundred kilovolts. The main challenge is finding a method to extract a small amount of charge from the discharge cable to trigger the device. Suggestions include using a parallel resistor arrangement to divert charge, though the creator is open to alternative ideas. The conversation emphasizes the importance of detailing progress and goals in project submissions.
rabrave
am doing my final year project on designing and constructing the device i have named up there.
It is an electronic device which is to be attached with the discharge rod and give an appropriate signal if the discharge process was successful or not.
The challenge is, the device is to be used in high voltage laboratories, the capacitors are charged to hundred Kilovolts.
I would appreciate some suggestions on how i can scoop a small amount of charge from the discharge cable and use it to trigger my device to operate as the capacitor discharges.
>I though of using a parallel resistor arrangement to branch the charge to my "security accessory", but still am curious to know if someone may have a better way
This should be placed in the Homework Help section. Show what you have done so far, enumerate your goals, and show what you have accomplished so far.
too wide that i can't easily get to homework page!
