Discrete and continuous problems
haiha
Hi all,
There are some dificult problems with discrete argument n that will be very easy if I can change it to continuous argument x. But I do not know what is the condition for that.
For example: to calculate the sum of a1+a2 +a3+...an. when n goes to infinity, can I make it as S=integral of a(x) from xo to infinity ?
Thanks
It depends very much on how you define a(x) for x not an integer.
Could you please explain more about that.
I just think the sume of An is similar to the way we calculate the integral in calculus. I mean Sum(An) = a1*d+a2*d+...an*d where d equals 1. When we calculate to rather large integer n, then d = 1 is small enough to have adequate accuracy.
May I think that this can happen only when f(x) must have positive (or negartive) derivative all over the domain, and f(x) must also have no critical points. ?
Since a(x) has to be defined for x not integer, the integral will depend on precisely how it is defined. For example, linear interpolation between the integer values will give you a function which can be integrated to give the same result as the summation.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
