MHB Why does the population go to extinction if the solution is real?
The discussion centers on a mathematical model describing population dynamics under predation, represented by the difference equation u_{t+1} = (au_t^2)/(b^2 + u_t^2). It identifies equilibria at u_* = 0 and u_* = (a ± √(a² - 4b²))/2, indicating that if a² > 4b², extinction is possible if the population falls below a critical size. The analysis reveals two attractive fixed points and one repulsive fixed point, suggesting that populations starting below a certain threshold will decline to extinction. The recursive nature of the model shows that if the initial population is less than the critical size, it will converge to zero, leading to extinction. Thus, even with real solutions, the population can go extinct due to the dynamics of the model.
Dustinsfl
The population of a certain species subjected to a specific kind of predation is modeled
u_{t+1}=\frac{au_t^2}{b^2+u_t^2}, \quad a>0.
Determine the equilibria and show that if $a^2 > 4b^2$ it is possible for the populationto be driven to extinction if it becomes less than a critical size which you should find.
So the steady states are
$u_*=0$
$u_*=\frac{a\pm\sqrt{a^2-4b^2}}{2}$
So why if the solution is real, does the population go to extinction?
Mathematics news on Phys.org
$u_*=0$
The recursive relation can be written in the form...
$\displaystyle \Delta_{n}=u_{n+1}-u_{n}= - \frac{b^{2}\ u_{n} - a\ u^{2}_{n} - u^{3}_{n}}{b^{2}+u^{2}_{n}}= f(u_{n})\ ,\ a>0$ (1)
Under the hypothesis that is $a^{2}>4\ b^{2}$ and that is $u_{n} \ge 0\ \forall n$ the function f(x) has two 'attractive fixed points' in $x_{0}=0$ and $\displaystyle x_{+}= \frac{a+ \sqrt{a^{2}-4 b^{2}}}{2}$ and a 'repulsive fixed point' in $\displaystyle x_{-}= \frac{a- \sqrt{a^{2}-4 b^{2}}}{2}$. The solution of (1) depends from the 'initial state' $u_{0}$ and precisely...
a) if $0 \le u_{0} < x_{-}$ the sequence has limit $x_{0}=0$...
b) if $u_{0}=x_{-}$ the sequence has limit $x_{-}$...
c) if $u_{0}>x_{-}$ the sequence has limit $x_{+}$...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
Unfortunately, I just don't understand what you are doing to help in this post (or the others). I am not saying you aren't helping. I just don't understand your procedures and methods.
On MHF I wrote a tutorial section where the general procedure for solving this type of recursive relations was illustrated ... 'unfortunately' MHF collapsed and now, with the approval of Administrators, I can try to rewrite the same tutorial section on MHB...
Kind regards
$\chi$ $\sigma$
$u_*=0$
Consider:
\[ \frac{u_{t+1}}{u_t}=\frac{au_t}{b^2+u_t^2}\]
\( \{u_t\} \) is a decreasing sequence if the above is less than \(1\). So solve:
\[ \frac{au_t}{b^2+u_t^2}<1\]
and the result will follow (you will need to justify it going to zero rather than decreasing to a non-zero limit but that is easily done).
CB
CaptainBlack said:
Consider:
CB
I am not sure how or why the result follows? That leads me to the same quadratic to solve but with an inequality.
From the cob web plot, I see there is only the zero steady state when a^2<4b^2
How could there be a critical extinction point if the only steady state is 0?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
