Calculating Revolutions with Constant Force: Solving for Angular Velocity
  • Thread starter Thread starter blackbyron
    Disk String
A solid disk with a radius of 3.3 cm has 1.0 m of string unwound from it by a constant force over 4.9 seconds. The calculations involve determining the angular velocity and revolutions made by the disk during this time. Using the relationship between linear distance and angular displacement, the disk completes approximately 4.82 revolutions as the string is pulled. The discussion also touches on the use of torque and moment of inertia in the context of angular acceleration. The conclusion emphasizes the direct relationship between the string's travel distance and the disk's rotation.
blackbyron
A solid disk with a radius of 3.3cm is a rest. The disk has 1.0m of string wound on to its circumference. The string is pulled off the disk by a constant force in a time of 4.9s. How many revolutions dose the disk make while the string is being pulled off?
1 rev = 2*pi
V =(2*pi*r)/t
find velocity.
Do I need to start off using energy converstion?
(1/2)(m)(v^2) = m*g*x
and I'm lost here
Any help will be appreciated.
Assuming that the disk is spinning on the z-axis with no friction, consider that M = dL/dt = I*dω/dt, where M is torque, L is the angular momentum and I is the moment of inertia.
The string is pulled with a constant force F on a distance s = 1m in 4.9 seconds.
M = I*dω/dt = I*d(v/r)/dt = (I/r)dv/dt
Since dv/dt = a, and it's a constant acceleration due to a constant force, then:
M = (I/r)Δv/Δt
MΔt = (I/r)Δv
Remember, M = dL/dt = ΔL/Δt, since the change is constant.
(ΔL/Δt)Δt = (I/r)Δv
ΔL = (I/r)Δv, ΔL = Lf - Li = Lf = Iωf
f = (I/r)Δv
ωf = Δv/r, Δv = vf - vi = vf = Δs/Δt = 1 m/4.9 seconds
Then, θ = (ωf - ωi)*Δt = ωf*Δt = (Δv/r)Δt = (ΔsΔt)/(rΔt) = Δs/r
Revolutions = θ/(2pi) = Δs/(2r*π) = 1 m /(2*0.033 m * π) = 4.822... revs.
Another way to see it is that, since the string is wound around the disk, the disk's circumference must also spin the same distance the string would need to travel. In other words, if the string travels 1 m, the circumference travels 1 m.
I see you're using inertia to solve, don't know why my teacher didn't talk about that on angular acceleration.
But Thanks, tho, I'll take some time to look at it.
