Finding Displacement Amplitude of a Pressure Wave
The discussion revolves around calculating the displacement amplitude of a pressure wave given the pressure variation equation. The user correctly identifies that the maximum value of the sine function is 1, leading to the conclusion that the maximum pressure change, ∆Pmax, is 20.0 pascals. However, the user struggles to apply the relationship between pressure amplitude and displacement amplitude due to confusion over the calculation of ∆Pmax. The final calculation yields an incorrect displacement amplitude, prompting the user to seek clarification on their approach. The correct displacement amplitude is ultimately stated to be 9.05 μm, indicating a misunderstanding in the application of the formulas.
roam
A traveling sound wave causes a variation in air pressure according to the equation:
∆P = 20.0 sin(15.5x − 5.32 × 103t )
where x is in metres, t in seconds and pressure is in pascals.
What is the amplitude of the displacement of the air particles caused by this pressure wave (i.e. the displacement amplitude)?
Take ρair=1.21 kgm–3.
Pressure amplitude is related to displacement amplitude by
\Delta P_{max}= \rho v \omega s_{max}
I know that the angular frequency ω of the pressure wave is 5320.0 rads–1, and the velocity v of the pressure wave is 343.0 ms–1. But I can't use the formula above because I can't determine the value of \Delta P_{max}.
How can I find \Delta P_{max} from
when I don't know the values of "x" and "t"? What values do I need to substitute there?
∆P is sinusoidal, what is the maximum value that sine of anything can take?
I think the maximum value for sine is 1. So we must have:
(15.5x − 5.32 × 103t ) =1
Okay, then we get:
∆Pmax = 20.0 sin(1)= 0.34
0.34= 1.21 \times 343 \times 5320 S_{max}
S_{max} = \frac{0.34}{2207959.6}= 1.53 \times 10^{-7}
But this is not the correct answer, the correct answer must be 9.05 μm. What am I doing wrong here??
Yes.
roam said:
So we must have:
If the maximum of sine is 1, then shouldn't sin(15.5x − 5.32 × 103t ) =1?
Thank you so much! :redface:
