Amplitude of Piston in Horizontal Cylinder
In a horizontal cylinder with a piston performing simple harmonic motion, the amplitude of the piston is not equal to the displacement amplitude of the medium, which is air in the cylinder. The medium itself does not move in the same way as the piston; it only expands and contracts due to the piston's motion. The displacement of the medium refers to the changes in pressure and density rather than physical movement. Understanding this distinction is crucial for analyzing the dynamics within the cylinder. The discussion clarifies the relationship between the piston's motion and the behavior of the medium.
zia
consider horizontal cylinder in which piston is performing simple harmonic motion.Is the amplitude of piston is equal to displacement amplitude of elemnts pf medium i.e air in the cylinder.
I don't understand what you mean by "displacement of the medium." The medium in the cylinder is not moving, just expanding and contracting.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
