Displacement current in Maxwell equations
snyski
Does anyone know how to solve or at least how to begin solving the following problem?:
Prove that displacement current in the Maxwell equations can be neglected if characteristic time τ of changing electromagnetic field in the system satisfies to the following condition: τ >> L/c where L is the characteristic size of this system and c is light speed. (Hint: time derivative of some variable y can be approximated as ratio of its characteristic value to characteristic time, dy/dτ ≈ y/τ the similar approximation can be also used for spatial derivatives).
Can you write down the relevant Maxwell equation, then change all derivatives in length and time to simple division by their charactersitic values?
I believe I can use the following relation:
Equation: curl of B equals mu0 times j plus epsilon0 mu0 times the partial derivative of E with respect to t, the Ampère-Maxwell law in vacuum.
Defining the current density of J as the displacement current, by differentiating D with respect to time
Equation D = ε0 E + P, where D is the electric displacement field, ε0 the vacuum permittivity, E the electric field and P the polarization.
(dD/dt)We get:
Equation J_D = ε0 ∂E/∂t + ∂P/∂t, the displacement current density expressed as the time derivative of the electric field times vacuum permittivity plus the time derivative of polarization.
With B and E being defined as:
Equation: nabla dot B = 0, the differential form of Gauss's law for magnetism stating that the divergence of the magnetic field B is zero.
Maxwell-Faraday equation: curl of E equals negative partial derivative of B with respect to time, written as ∇ × E = −∂B/∂t.
So instead of differentiating to time I can now simply divide by time? However, I don't quite see where light speed comes in and how I could prove the displacement current actually being neglectable.
