Distance a rotating turnable moves
  • Thread starter Thread starter preluderacer
    Rotating
To find the distance a point on the edge of a rotating turntable moves, the formula involves multiplying the angle in radians by the radius. For a turntable with a radius of 2.2 m turning through 1.1 radians, the distance is calculated as 1.1 radians multiplied by 2.2 m, resulting in 2.42 m. The discussion also touches on converting degrees to radians for similar calculations, suggesting that the formula can be adapted by replacing degrees with their radian equivalent. Understanding the relationship between circumference and angular displacement is key to solving the problem. This approach clarifies how to calculate linear distance from angular movement.
preluderacer
The radius of a rotating turntable is 2.2 m. If it turns through an angle of 1.1 radians, through what distance does a point on the edge move?
I can't find an equation that will give me the distance. Is this like 2 parts or am I just blind to see this equation?
do you know the equation for the circumference of a circle?
is it just radians x radius?
Ok I got the circumference do I just multiply it by the radians?
im still lost on this any inputs?
What would you do if it was degrees instead of radians?
(degrees turned)/(total degrees possible 360) x circumference
Now replace the degree portion with a Radian equivalent.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
