Distance between point charges in equilibrium (simple)
To determine the location of a third charge that experiences no net force between two fixed charges of +1.07 µC and -3.28 µC, the equilibrium condition requires that the forces exerted by the two charges on the third charge be equal in magnitude and opposite in direction. The initial calculations led to an imaginary distance, indicating a mistake in the setup. Upon reevaluation, it was noted that the third charge should not be placed closer to the larger magnitude charge. Correcting the placement of the charges and ensuring the forces are balanced resolved the issue, leading to the correct answer. The discussion highlights the importance of accurately applying Coulomb's law in equilibrium problems.
Mitocarta
Two fixed charges, +1.07 uC and -3.28 uC, are 61.8 cm apart. Where may a third charge be located so that no net force acts on it?
Coulombs law
q1 = 1.07 uC
q2 = -3.28 uC
q3 = q
q1 ----- q2 ----- q
q1 and q2 are separated by 0.618 m and q2 and q are separated by x
Since the charges are in equilibrium,
0 = k (1.07E-6)(q) / (0.618+x)^2 + k(1.07E-6)(q) / (x)^2
factoring out and eliminating k and q,
(1.07E-6)/(0.618+x)^2 + (3.28E-6)/(x)^2 = 0
Solving for x gives me an imaginary distance. I feel like this is a very simple problem but I can't spot my error. What am I doing incorrectly? Thank you for your time.
Hello Mitocarta, welcome to PF!
You've placed q closer to the larger magnitude charge. Is that going to work?
Thank you for replying. When I switch the charges,
(3.28E-6)/(0.618+x)^2 + (1.07E-6)/(x)^2 = 0
I still get an imaginary answer.
Edit: Is there a way to input math in an easier to read format on this forum?
The two forces act in opposite directions on q. The net force will be zero if the magnitudes of the forces are equal to each other.
Oh I was overlooking that! Thank you so much, got the correct answer.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
