Distance of closest approach of particles
A proton and an alpha particle are fired towards each other with an initial speed of 0.01c, and the problem requires finding their distance of closest approach. The conservation of momentum and energy equations are applied, with the initial kinetic energy and potential energy at infinity considered. The calculations involve determining the final velocity and equating kinetic energy lost to potential energy gained due to electrostatic forces. A correction is noted regarding the initial speed used in calculations, emphasizing the need to use the specified 0.01c. The final result for the distance of closest approach is calculated to be r = -1.92 * 10^{-18} m, prompting further discussion on the validity of the approach.
KillerZ
A proton (q = 1e, m = 1u) and an alpha particle (q = +2e, m = 4u) are fired directly toward each other from far away, with an initial speed of 0.01c. What is their distance of closest approach, as measured between their centers? (Hint: There are two conserved quantities. Make use of both.)
K_i + U_i = K_f + U_f
m_1v_{1i} + m_2v_{2i} = m_1v_{1f} + m_2v_{2f}
How does this look?
e = 1.60 * 10^{-19} C
c = 3.00 * 10^8 m/s
u = 1.661 * 10^{-27} kg
(4u)(3 * 10^8 m/s) - (u)(3 * 10^8 m/s) = (4u + u)v_{f}
v_{f} = \frac{(4u)(3 * 10^8 m/s) - (u)(3 * 10^8 m/s)}{(4u + u)}
v_{f} = 1.80 * 10^8 m/s
\frac{1}{2}(m_{1}+m_{2})v_{f}^{2} + \frac{1}{4\pi\epsilon_0}(\frac{q1q2}{\infty}) = \frac{1}{2}(m_{1}+m_{2})v_{i}^{2} + \frac{1}{4\pi\epsilon_0}(\frac{q1q2}{r})
\frac{1}{2}(4u + u)(1.80*10^8 m/s)^{2} = \frac{1}{2}(4u + u)(3.00*10^8 m/s)^{2} + \frac{1}{4\pi\epsilon_0}(\frac{2(1.60*10^{-19} C)(1.60*10^{-19} C)}{r})
4\pi\epsilon_0(\frac{1}{2}(4u + u)(1.80*10^8 m/s)^{2} - \frac{1}{2}(4u + u)(3.00*10^8 m/s)^{2}) = (\frac{2(1.60*10^{-19} C)(1.60*10^{-19} C)}{r})
r= \frac{2(1.60*10^{-19} C)(1.60*10^{-19} C)}{4\pi\epsilon_0(\frac{1}{2}(4u + u)(1.80*10^8 m/s)^{2} - \frac{1}{2}(4u + u)(3.00*10^8 m/s)^{2})}
This might sound stupid (I am tired...) but, did not the problem state that the initial speed was 0.01c? As far as I can see, you used c as initial speed.
Use K.E. lost =P.E. gained.Consider the electrical P.E. only since the gravitational P.E.can be considerd as negligible.Also,the question is phrased in such a way that you can take the original separation to be infinite.
