Distance traveled in the nth second
In summary, Snth is the displacement in the nth second of a particle moving with uniform acceleration a. The difference between Sn and Sn-1 is the displacement in the nth and (n-1)th second of the particle.
Indranil
177
∆sn = sn - s(n-1)
In the distance in nth seconds formula above, I don't understand 'sn' and (n-1) means what? Could you explain it, please?
Where did you find this equation? In a textbook? What does the book say? You have been told before, it's your responsibility to tell us what your symbols mean.
Have a think. Distance traveled in the nth second. Is the difference between two quantities. Any idea what those two quantities might be, just from physical intuition?
I am giving the detail information which my book have below
'Consider a particle starting with initial velocity u and moving with uniform acceleration a. Let the displacement of the particle in the nth second of its motion be Snth. Snth = Sn - (sn-1)
When Sn and Sn-1 are displacements are the particle in n and n-1 seconds. The values of Sn and Sn-1 can be obtained by putting t = n and t = n-1 in the equation. S = ut + 1/2 at^2
Snth = u + 1/2 a (2n-1)'
∆sn = sn - s(n-1)
It's just the same formula using slightly different notation. ∆sn is the same as Snth; sn is the same as Sn and s(n-1) is the same as Sn-1.
∆sn = sn - s(n-1)
It seems likely that there is some problem with transcription from the textbook (presumably typeset) and ASCII text here on Physics Forums. The resulting notation is clumsy at best.
We have two functions, ##S## and ##S_{nth}##.
The function ##S## is defined as the displacement after a total of n seconds. So ##S(t) = ut + \frac{1}{2}at^2##
The function ##S_{nth}## is defined as the incremental displacement that takes place during the nth second. So ##S_{nth}(t) = S(t+1) - S(t)##
If you write ##S(t+1)## and ##S(t)## as formulas involving u, t and a then you should be able to derive a simple formula for ##S_{nth}(t)##
Note that I disagree with author's decision to use "nth" as part of the function name. The dummy variable in a function has no useful relationship with the function name. It's like writing ##sin_\theta(\theta)##: completely inappropriate. Hence the choice to use something other than n as the dummy variable in this response.
Yes.
Snth(t) = S(t +1) - St
In the formula above given by you, Could you please explain what S(t + 1) and what St means?
I don't get what you don't understand. You quote for your own formula:
"Snth = Sn - (sn-1) When Sn and Sn-1 are displacements are the particle in n and n-1 seconds."
And you can't work it out when you use t instead of n? jbriggs444 even defines S(t) for you. What's your problem?
Please use notation consistently. I never wrote "St". Failure to transcribe accurately may explain why the equation supposedly quoted from the textbook is so badly mangled.
The notation where a single letter is followed by a parenthesized expression most commonly denotes function evaluation. The single letter is a function. The parenthesized expression is the function argument. The value denoted is of the function evaluated for the specified argument.
Example: notation for function evaluation
If f(x) = x+1 then f(3) = 4.Note that the notation is "overloaded" and can have a different meaning depending on context. If the single letter has been declared as a function then the meaning is function evaluation as above. If the single letter has been declared as an ordinary variable then the meaning is taken as multiplication.
Example: multiplication denoted by juxtaposition
if f = 7, a = 2 and b = 3 then f(a+b) = 7(2+3) = 35
In a properly written mathematical work, all functions and variables will be declared before use. As a result, there is no ambiguity.
In the formula above given by you, Could you please explain when to use S(t + 1) and when to use St? and the formula given by me doesn't match the formula ' Snth(t) = S(t +1) - St' [ my formula is ∆sn = sn - s(n-1)]
Again, I never gave that formula. You misquoted it.
If you want to quote that accurately, use the "Reply" action. The entire post (excluding embedded quotes), including LaTeX formatting will appear in your message window. You can then edit it down to just the passage of interest.
If you attempt to quote by highlighting a passage and clicking to select Reply, you will get a poorly formatted result.
Ok, Sorry. Please forgive me for misquoting you.
In the formula above, what does S(t) means together? as I know S = displacement and t = time
The notation -- a symbol followed by a parenthesized expression denotes the value of a function. As I wrote in the passage that you quoted:
"The function ##S## is defined as the displacement after a total of n seconds".
As in all of mathematics, a thing means what is defined to mean. No more, no less. I defined the function S in that passage. Accordingly, it means what the definition says that it means.
What does "distance traveled in the nth second" mean?
"Distance traveled in the nth second" refers to the total distance traveled by an object during the nth second of its motion. This can be calculated by multiplying the average velocity of the object during that second by the duration of the second.
How is the distance traveled in the nth second calculated?
The distance traveled in the nth second can be calculated by using the formula "distance = average velocity * time". This formula takes into account the average speed of the object during that second and the duration of the second.
Is the distance traveled in the nth second the same as the displacement in that second?
No, the distance traveled in the nth second and the displacement in that second are two different measurements. Distance is the total length of the path traveled by the object, while displacement is the shortest distance between the initial and final position of the object.
Does the distance traveled in the nth second depend on the initial velocity of the object?
Yes, the distance traveled in the nth second is affected by the initial velocity of the object. The higher the initial velocity, the greater the distance traveled in that second will be.
Can the distance traveled in the nth second ever be negative?
No, the distance traveled in the nth second cannot be negative. Distance is a scalar quantity and only represents the magnitude of the displacement, not its direction. Therefore, it will always have a positive value.
  • Set Theory, Logic, Probability, Statistics
  • Precalculus Mathematics Homework Help
  • Other Physics Topics
  • General Math
