Distributing 6 Distinct Molecules Across 3 Energy Levels
  • Thread starter Thread starter patcho
    Molecules
The discussion focuses on determining the number of ways to distribute 6 distinguishable molecules across 3 energy levels, specifically with 3 molecules in the first level, 2 in the second, and 1 in the third. The correct approach involves using combinations to calculate the arrangements, applying the formula nCr = n! / (r! * (n-r)!). The calculation yields 60 distinct arrangements, derived from the combinations of molecules for each energy level. The explanation clarifies the confusion regarding the distribution and emphasizes the importance of using the combination formula correctly. This method effectively resolves the original question about the distribution of molecules across energy levels.
patcho
Hi,
I'm not quite sure about this question:
'How many Ways can 6 distinguishable molecules be placed in 3 different energy levels with 3 molecules in the 1st level, 2 in the 2nd level and 1 in the 3rd level, ignoring energy required?'
If it was just how many ways to place them in 3 different levels it would be easy but how to always keep 3 molecules in the first, 2 in the 2nd and 1 in the first confuses me.
I know that the number of Ways is less than before and I'm thinking along the lines of having to divide the number obtained if it was just 3 different energy levels, by 3!2!1! (the number of molecules in each level). This gives: W=10 which I think is very wrong!
Any help appreciated!
:smile:
Take a slightly more general question:
How many ways can N numbered balls be grouped into three sets such that the first group contains n_1 balls, the second set n_2 balls and the third set N-n_1-n_2 balls?
Hint: How many ways are there to choose the first set? After that, in how many ways can you choose the second set?
Hi there,
Thank you for your question. It seems like you are trying to figure out the number of possible arrangements for 6 distinguishable molecules in 3 different energy levels, with specific numbers of molecules in each level.
In this case, you can use the concept of combinations to find the number of ways to place the molecules. The formula for combinations is nCr = n! / (r! * (n-r)!), where n is the total number of objects and r is the number of objects being chosen.
In this problem, we have 6 molecules and we want to choose 3 for the first level, 2 for the second level, and 1 for the third level. So, the number of ways to place these molecules would be:
6C3 * 3C2 * 1C1 = (6! / (3! * (6-3)!) * (3! / (2! * (3-2)!) * (1! / (1! * (1-1)!)
= (6*5*4 / (3*2*1)) * (3*2 / (2*1)) * (1 / (1*0))
= 20 * 3 * 1
= 60
So, there are 60 ways to place 6 distinguishable molecules in 3 different energy levels with 3 molecules in the first level, 2 in the second level, and 1 in the third level.
I hope this helps clarify the concept for you. If you have any further questions, please feel free to ask. Best of luck with your studies!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
