Distribution function primitive
The discussion focuses on determining the cumulative distribution function (CDF) from a given probability density function (PDF). The user initially calculated the CDF for two intervals but was unsure about the constant value, c, which their teacher identified as 1/2. The teacher emphasized the importance of ensuring that the CDF meets boundary conditions, specifically F(-1) = 0 and F(1) = 1, to find the correct value of c. Additionally, there was a note on the importance of using distinct symbols for the PDF and CDF to avoid confusion. Understanding these concepts is crucial for accurately graphing the distribution function.
cham
the distribution function: f(x)=
x + 1 when -1 < x ≤ 0
-x + 1 when 0 ≤ x < 1
0 otherwise
on the first interval i found (1/2)x2 +x + c
on the second interval -(1/2)x2 + x + c
and when integrating the c's will cancel each other
now my math teacher found
on the first inervall f= (1/2)x2 +x+1/2
on the second f=-(1/2)x2 + x +1/2
f=1 otherwise
now i want to know how did find that c=1/2 because we have to draw the graph
It's not clearly stated, but I gather you are trying to find the cumulative distribution function from the density function. ('Distribution function' is not specific enough.)
Why do you say the c's cancel? Using the CDF you found for the second interval, including the unknown c, what does that tell you about the CDF at +infinity? What value must a CDF take at +infinity?
Likes cham
0 otherwise
f=1 otherwise
Please do not use boldface font for the whole message---only for parts you really want to emphasize (as I do below).
Mod note: I removed the excess boldface.
Anyway: you need F(-1) = 0 and F(1) = 1, so that tells you what must be the value of c.
Note: do NOT use the same letter, f, for both the density function and the distribution function; your second function should be called F, or at least by some other symbol different from your first f. Using the same symbol for two different quantities in the same problem is a sure way to lose marks for no good reason!
Likes HallsofIvy
