Divergence free vector fields in R^n
Every divergence-free vector field in R^n, where n>1, can be expressed in the form v(x)=SUM dAij/dxi *ej, with Aij(x) being a smooth skew-symmetric function. The divergence of the vector field is zero if the form holds true, which can be verified through calculations involving the properties of Aij. The discussion includes attempts to solve the problem using induction and the divergence theorem, relating integrals over closed surfaces to the vector field. Some participants express confusion about concepts like pseudovectors and forms, indicating a need for foundational knowledge in differential operators. The conversation highlights the complexity of proving the existence of such a tensor Aij and the challenges faced by those unfamiliar with advanced mathematical concepts.
szf654
Prove that every divergence free vector field on R^n, n>1 is of the form:
where Aij(x) is smooth function from R^n to R such that Aij(x)=-Aji(x) i.e. matrix $[Aij(x)]$ is skew symmetric for every vector x.
Is this homework ? If so, you're in the wrong section and you should post your thoughts before asking for help. That's normally how homeworks are dealt with.
Thanks for pointing out, I am new here :)
OK, good. So what are your ideas to solve the problem ?
Oh, I reposted into homework section, but let me write here as well.
2. Homework Equations
Divergence of field v at p is Sum dv(x)/dxi. Vield is a divergence free if dv(x)/dxi=0 for every x.
Divergence theorem: integral div v over S=integral v*n over dS where n is vector pointing out on dS (boundary of S).
3. The Attempt at a Solution
First I checked that the converse is true, i.e. if the vector field v has form (**) it is divergence free. That can be done by simple calculation div v and using that Aij is smooth so d^2 Aij/dxi*dx=d^2 Aij / dxj*dxi (i.e. order of differentiation does not matter) and we also use Aij+Aji=0.
My attempt was to use induction as noted in the pset, i.e. by using divergence theorem we get that integral v*n over dS for every closed surface. My idea was to somewhat relate this integral to a div free vector field over R^{n-1}, but I did not manage that.
Second thing I tried is to somehow integrate over line parallel to e^j and get non differential relationship between v and Aij, but I am not sure if that is a legitimate field and how to define Aij in that way properly.
Thanks for help!
A_ij is the 2 form dual to a pseudovector in 3 D. Any pseudovector is the curl of a vector.
So
A_{ij} = \epsilon_{ijk} \tilde{B}_k = \epsilon_{ijk} (\nabla \times \vec{C})_k
Now you know that \nabla\cdot\vec{D} = 0. From these 2 things you can infer that
\vec{D} = \nabla \times\vec{C}
where \vec{C} is determined up to a gradient of a scalar.
Thanks, but to be honest I am familiar with the curl, but its the first time I hear about pseudovector and forms. Is there a way to avoid using it?
Divergence and curl are differential operators acting on vectors in R^3 and generally in R^n. Also the gradient and the laplacian. You must know about them, if you're into this problem.
Well in my class we did not define them, just the divergence, and we are still required to solve this problem.
In this case, you can exploit the fact that the derivative operators commute and contract them with an arbitrary antisymmetric tensor.
\partial_i v_i = 0 \leftrightarrow v_i = \partial_j A_{ij}, A_{ij} = -A_{ji}
To show that such a tensor exists means to solve a system of PDEs of 1st order (3eqns for 3 independent components of A).
It seems that your look at this problem is way above my level of understanding :)
  • · Replies 24 ·
