A: How do you use the divergence theorem to find the flux through a unit sphere?
In summary, this problem is either really easy, or I'm really dumb, and since there are no answers to check my work I figured someone here might want to help :)
FrogPad
810
This problem is either really easy, or I'm really dumb, and since there are no answers to check my work I figured someone here might want to help :)
Q: [itex] w=(x,y,z) [/itex] what is the flux [itex] \int \int w \cdot n\,\, dS [/itex] out of a unit cube and a unit sphere? Compute both sides in the divergence theorem?
A: ?
[tex] \vec w = (x,y,z) [/tex]
[tex] \int \int \vec w \cdot n \,\,dS = \int\int\int div \,\vec w \,\,dV [/tex]
[tex] grad \cdot \vec w = 3 [/tex]
[tex] 3\int dV = 3 \times vol_{sphere} = 4\pi [/tex]
Over what volume are you supposed to integrate? For a unit sphere, what you did is right. What about the cube?
Check the definition of the divergence theorem again.
I just wanted to make sure I wasn't misinterpretting the definition of the divergence theorem. It's been awhile since I've had practice using it.
To complicate things for my own good. (maybe this should be another thread... but I guess it still does pertain to this homework problem). Let's say [itex] \vec w = (x^2,y^2,z^2) [/itex].
And let's say I'm asked to find the flux through a unit sphere.
Would this be a logical way to arrive at the answer.
First compute the divergence: [itex] div\, \vec w = 2x+2y+2z[/itex]
Now the integral would be of the form: [itex] 2\int \int \int (x+y+z) \,\,dV [/itex]
I could convert [itex] (x+y+z) [/itex] to spherical coordinates. Setup the limits of integration in spherical coordinates, and that would be the flux through the sphere?
I'm thinking this right. But perhaps I'm not visualizing it properly. The way I'm visualizing it right now is that I have this cube in space full of numbers, I can get to each number by feeding coordinates to it [itex] x,y,z [/itex]. Then in this visualization exercise the volume of integration is actually all the numbers I want to feed to this cube and pull those numbers. So I'm actually feeding every coordinate within the sphere to this cube. I hope that actually makes sense and am applying this thought properly. Thanks for the help.
What is the Divergence Theorem?
The Divergence Theorem, also known as Gauss's Theorem, is a fundamental theorem in vector calculus that relates the surface integral of a vector field to the volume integral of the divergence of that vector field.
What is the significance of the Divergence Theorem?
The Divergence Theorem is significant because it allows for the simplification of certain surface and volume integrals, making it a valuable tool in solving problems in fields such as physics, engineering, and fluid mechanics.
What are the conditions for the Divergence Theorem to hold?
The Divergence Theorem holds for any smooth, simply connected region in three-dimensional space, and the vector field must have a continuous first partial derivative in that region.
How is the Divergence Theorem related to other theorems in vector calculus?
The Divergence Theorem is closely related to two other important theorems: Stokes' Theorem and Green's Theorem. Together, these theorems form the basis of the fundamental theorem of calculus for vector fields.
Can the Divergence Theorem be extended to higher dimensions?
Yes, the Divergence Theorem can be extended to higher dimensions through the use of differential forms and the generalized Stokes' Theorem. In higher dimensions, the Divergence Theorem relates the (n-1)-dimensional surface integral of a vector field to the n-dimensional volume integral of the divergence of that vector field.
