Divergent Series: Finding the Largest Value of n
  • Thread starter Thread starter eddybob123
    Divergent Series
To determine the largest value of n for which the series $$\sum_{k=1}^\infty\frac{1}{k^n}$$ diverges, the integral test can be applied. The harmonic series, occurring at n = 1, is a well-known example of divergence. For values of n greater than 1, the series converges. Therefore, the largest value of n for divergence is 1. Understanding this relationship is crucial for analyzing the behavior of p-series.
eddybob123
Hi all, is there any way to find what the largest value of n is such that $$\sum_{k=1}^\infty\frac{1}{k^n}$$ is divergent? I don't need an answer, I need an approach to the problem.
Mathematics news on Phys.org
Integral test.
It is well known that if n = 1, the series is the harmonic series, which diverges.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
