s3a said:
Basically, this thread is just about (basic) Astrophysical theory because the Math is quite simple. I am attaching a set of word problems and all I am asking for is to get feedback on whether or not I am correct or not about the formulas I am planning to use for each question. If I am wrong about one of my choices of formulas, it would be appreciated if you could explain why I am wrong and provide me the correct formula as well as the related background theory. I'm most uncertain about the last question (#3).
You equation for 1a seems fine. It's just the Wien-Displacement Law.
For 1b, your equation is totally wrong. E = hc/λ is the equation for the energy of a
single photon of wavelength λ. You want to know the energy emitted (typically per unit time and per unit surface area) by a perfect thermal blackbody emitter at temperature T. For this, you need to look into the
Stefan-Boltzmann Law.
More on why you are wrong: A blackbody is going to emit many photons over a very large range of wavelengths (it has a continuous, broad spectrum). The λ from 1a is just the wavelength at which
peak emission occurs.
Your equation for the flux in 1c is fine, provided that you get the luminosity correct from part b. (Recall that luminosity is just the astronomy term for the total power in EM radiation emitted by a source, so it's the thing you are looking for in part b).
For 2, your formula for the size of the diffraction disk is
approximately right,
assuming that you want the result in arcseconds.
s3a said:
I think I know what Very Long Baseline Interferometry is in theory but, to apply the math, is it the same formula as #2? Is a baseline analogous to a diameter of a telescope from #2? Are baselines the distances between the antennas? Are antennas telescopes in this context? (I am a bit confused about that part). Also, I am not asking for you guys to solve my problem(s) but you can if you want to
Yes, the baseline is the distance between antennae. Yes, the terms "antenna" and "radio telescope" are not any different in this context. (In fact, if you look closely at a satellite receiver dish, you'll notice that it is essentially a prime focus telescope, which is one that has a primary mirror, but no secondary, since the detector/receiver is right at the focal point in front of the primary). And yes, if I recall correctly, the "effective" diameter of your telescope can be considered to be the length of the longest baseline in your interferometer (that's why you do interferometry -- to achieve much better angular resolution than you could with a single dish telescope at any practical size). If that's true, then you're right, you would just use the same equation for the diffraction-limited resolution as in part 2, but with D being the "effective" diameter. However, you will want to double-check this last claim of mine, because it's been a while for me since I read about interferometry.
I know you were half joking about someone doing the problems, but I just wanted to emphasize that, no, we won't do your homework for you, we don't do that here at PF (it is, in fact, against the rules). But we're more than happy to help you learn. Also, for future reference, this post should have been in the Homework Help section of the forums, not in the Astronomy subforum.
