Do I still have a chance at a C+ / better?
  • Thread starter Thread starter Edin_Dzeko
The discussion centers around a student who scored 61 on their first chemistry test but received a 0 for the second test after choosing not to attend, believing it would be a waste of time. The student is concerned about their chances of passing the class, which requires a total score of 280 across four tests and a final. Responses emphasize the difficulty of passing given the current scores, suggesting that the student would need to achieve exceptionally high scores on the remaining tests to pass. Many contributors recommend dropping the class, criticizing the decision to skip the second test and highlighting the importance of effort and attendance. Some suggest that even if the class is curved, the student's approach is unlikely to yield a passing grade. Overall, the consensus is that without significant changes in effort and strategy, passing the class seems unlikely.
Edin_Dzeko
I got a 61 / 100 on my first Chem test. There are 4 test and a final. I didn't bother showing up for the second test I just didn't want to go in there and waste time. I didn't know squat so I decided not to show up. That's a 0. I don't think the prof allows a make up without a doctor's note.
So
Test 1: 61/100
Test 2: 0/100
Test 3:
Test 4:
What do you think my chances are? Can I still pass the class?
Are you asking for people to abuse you? Perhaps you came to right place.
abuse? why and how?
If a C is 70%, then you need a total score of 280 on 4 tests. Less the 61 you already got, that means on the last two tests and the final (assuming each is weighted equally, which they probably aren't) you need a total of 289, or about 97 on each test. That means you need to learn everything you should have learned when you were wasting time, plus all the new stuff. If I were you, I'd drop the class. Those sorts of scores would be difficult for a good student to get.
You should drop the class in my opinion.
If you decided not to show up because you didn't know any of it and thought it was a waste of time, it seems like you just didn't put forth any effort in it as far as I can tell.
Given you didn't show up to an exam for reasons other than things out of your control (Family death, health problems, etc).
Drop the class.
Get a fake doctor's note?
Drop the class unless you can somehow convince the professor to give you a better grade.
Is the class curved? Anyways, you really need to work harder. You shouldn't just 'not show up' to tests and hope to get a C+ in the course. It's disgraceful.
Dude it's okay, here is what happpened with me
Midterm 1: 20%
Midterm 2: 97.3%
Average so far? 70% Yay...now I just got to wait for the finals to bring my grades down even further
You'd be surprised what you can pull out of your *ss on some exams, even if you don't actually know all that much. Especially if the class is an intro-level course, go get a problem set, take 20 minutes, and learn one concept or one type of problem really well. If you pick a concept or problem that the professor seems to like, odds are it or something like it will show up on the exam. Bam, 10 points. Got an hour before the exam? Repeat and hope you guess right.
It's certainly no way to learn the material, but if you're in over your head and just trying to survive with a passing grade, giving up and eating a 0 is a really weak option (unless you spent that time studying feverishly for something else that needed work). It's interesting that you thought spending an hour or two scraping the bottom of the barrel for lucky points would be a waste of time, yet you still seem to care whether you pass the class or not.
Midterm 1: 20%
Midterm 2: 97.3%
Haha, I was hoping for the same thing in my discrete class.
Midterm 1: 47%
Midterm 2: 49%
Didn't happen. Although the average was 53, so I'm not that far off. :redface:
To the OP...if you wouldn't have completely skipped that second exam, this wouldn't be as hard. I'm sure if you tried on the other two you could at least pull a C. Do you even have an option to drop at this point?
1) Is it theoretically possible to pass? I think yes. a good showing on the final is usually enough to pass.
2) are YOU going to pass? highly unlikely. You have exhibited behavior that is extremely inconsistent with that of someone who will pass. Indeed at some schools skipping a test without permissions would be sufficient grounds for the instructor to remove you from the roll. You might check whether you are still in the class. I would guess it certainly disqualifies you from getting any slack of any kind.
