Do light bulbs store energy?
  • Thread starter Thread starter solvejskovlund
The discussion revolves around the behavior of light bulbs when subjected to different electrical conditions, particularly in relation to a discharge test involving lithium-ion batteries. Participants explore whether light bulbs can store energy and the implications of using them in high-voltage scenarios.
  • Exploratory, Technical explanation, Debate/contested
  • One participant describes a setup using light bulbs to discharge lithium-ion batteries and questions why the bulbs burned out when reconnected to a standard AC supply after several weeks.
  • Another participant warns against connecting batteries in parallel without matching voltages and histories, citing safety concerns.
  • Some participants express confusion over the voltage requirements for lithium-ion batteries, noting that achieving over 800V would require a significant number of cells in series.
  • It is suggested that incandescent bulbs can only store thermal energy, which dissipates quickly, and that their failure may be related to electrical and thermal stress from being turned on and off.
  • Concerns are raised about the complexity of light bulbs as resistors and their sensitivity to electrical conditions.
  • One participant speculates that the failure of all bulbs simultaneously could be due to their different usage histories prior to the experiment.
  • Another participant emphasizes the importance of careful preparation when connecting batteries in parallel to avoid potential hazards.
  • A later reply questions the impact of switching from DC to AC on the bulbs' performance and failure.
Participants express various viewpoints regarding the causes of the light bulbs' failure, with no consensus on the exact reasons. There is agreement on the need for caution when working with batteries, but the discussion remains unresolved regarding the specific electrical effects on the bulbs.
Participants note that the lifetime of incandescent bulbs can be sensitive to thermal and electrical stress, and the discussion highlights the complexities involved in their operation under varying conditions.
solvejskovlund
I wanted to figure out which of my used li-on cells that would match, so I connected them all in parallel to make them equal, then connected them in series for a discharge test. This meant I needed something to use for discharging.... accepting over 800V. What I came up with was borrowing 3x 250V (ac) old style light bulbs from a lamp and connect them in series.
This setup was running for several days, I switched it on/off several times, to make sure it was only running while I was around and able to monitor the process. It all worked out great.
Several weeks later I put those light bulbs back into the lamp I borrowed them from running on 241V ac. At the very moment the light switch was turned on, there was a huge flash, and all the bulbs burned out immediately. Why did that happen?
I could imagine that the light bulbs can store energy, have some voltage. But not for several weeks. This does not make sense to me.
That's not a good idea. Batteries should only be placed in parallel if they have equal voltages and the same discharge/charge history. Connecting them in parallel can result in some of the stronger batteries trying to charge the weaker ones, which can cause heating and the potential for fire/explosion.
What kind of light bulbs are these? Are they incandescent or LED or some other technology?
Perhaps I am missing something, but what kind of li-ion batteries produces over 800V? As far as I am aware it is 4.2 V per fully charged cell, to get to 800+ volts you need almost 200 cells - but connected in series.
The only energy an incandescent bulb can store is the thermal energy of the hot filament. This energy will dissipate quickly and isn't really accessible in practice.
I think your issue relates to damage done to the bulbs, which could have occurred in a few different ways. The lifetime of incandescent filaments can be pretty sensitive to electrical (thermal) stress and mechanical stress. They like AC better than DC, and they don't like the thermal shock of being turned on and off, although those failures take a while. For example, a common assumption is that the life of the bulb versus applied voltage is something like the 13th power of the ratio applied/rated voltage.
The common light bulbs in your house are cost optimized for not being moved, operating from a very stable AC electrical source, and not being turned on/off more than a few of times each day.
https://en.wikipedia.org/wiki/Incandescent_light_bulb#Light_output_and_lifetime
You're right. 192 cells in series.
The shock of being turned on should be way heavier with the 800Vdc/3 (=266Vdc) that they survived several times than the first 241Vac shock that came only once. Any power on shock may kill a bulb. But all 3 of them at the same instant cannot be explained by ware. Most likely they had different use hours before going into my experiment.
OK. We don't know. Neither do you. That's how it goes with experiments that aren't scrupulously controlled. The fact that they all failed immediately makes me think you did something to them to greatly depleted their lifetime.
As a side note (I'll spare y'all the full diatribe), lightbulbs don't make great resistors. They are a lot more complex than many people realize.
@solvejskovlund -- Do you understand my comment/admonishment/warning? From your previous PF posts I know that you do not have much experience with electronics, so it is extremely important that you understand and acknowledge this warning. Please do not start a fire that could harm you or your loved ones or neighbors.
https://www.google.com/url?sa=t&sou...cKEwig3I-K64mSAxUAAAAAHQAAAAAQCA&opi=89978449
Sure. That's why they have to be prepared for the mission - make sure voltage is within a 50mV difference before connecting them. The purpose of parallel connection before series is to make sure they are perfectly balanced.
The old style, with a thin wire coil inside.
You're right. We don't know. At least I don't know.
I find it strange that the could be switched on/off many times during the test. If that load was weakening them so much, I find it strange that I would happen to stop the experiment at the very last power on/off they could handle. I feel confident that they would light up on DC once more if I had cycled the dc power once more. I think it must be something related to the apply AC after being used with DC, but I can't figure out what it is.
So incandescent bulbs, and some overstress by your stress is the likely issue in their failure.
My loved ones were kidnapped two years ago. There's nothing I can do with a battery to harm them.
Regarding my previous posts, I see them as there are 3 or 4 highly active users in here that focuses details that I don't see as relevant for the question asked, and they use that "missing", not relevant, information to bring the thread off topic by assuming that I ask something very different from what I write. These users may be the technical experts. But they are not experts in reading posts from not native english speaker who often don't know the proper english technical term. As an example there have been threads where I write that we have 240V grid supply here, and these "experts" assume I'm in the USA with 120V grid, and being an idiot for not understanding that I'm not living where they are.... Ḯ'm trying to not be offensive to anyone. Not even these "experts".
It is enough that one of them failed and shorted in any way (and for whatever internal reason) to burn two others as they are under 400 V now. That's actually the most likely explanation of what happened.
@solvejskovlund
I think I have a good guess as to what happened to your 3 bulbs. I think you had stressed them with your experiment slightly over their rated voltage and therefore also current, there are graphs on the internet but I believe that IIRC filament lifetime decreased exponentially not linearly with increased voltage above the rated voltage/current.
Then when you put them back and powered ON the lamp , I assume from what you said that all 3 bulbs were powered by a common phase/cable.
This means that if all 3 were already close to their practical life limit, one of them probably died first. Usually when a filament snaps/bursts open, it happens during power ON time when the temperature is increasing rapidly, as you apply power to the bulb the filament heats up rapidly and breaks, this can cause a inductive voltage spike because remember, the filament is basically just a wire made from different metal , if such a wire suddenly opens while current passes through there is now a situation where the current has nowhere to go, the built up magnetic field around the wires needs to dissipate its energy and it does so by increasing the voltage. This voltage spike could have put extra load on the nearby bulbs and given they were close to breaking themselves they then couldn't handle the extra load and also broke.
I can't imagine any other realistic scenario why would 3 bulbs fail at once, That or you have maybe a faulty power connection or some other factor we cannot imagine. Sometimes when a filament breaks it can even trip the breakers.
Also be careful with filament bulbs as resistors because during turn on their resistance is much lower than when they are hot.
The bigger the bulb the lower the resistance can be.
In case you do experiment with used or even new Li-Ion batteries please do that in a safe room that is made from non combustible materials or has fire extinction means placed at a short distance.
Please understand the moderators of this forums cannot and won't mandate you to stop doing what you do, but they have a legal obligation to not allow dangerous discussion on their controlled internet site - this forums, so they are not trying to be rude to you or jerks or whatever, they just don't want any legal troubles in a court of law in case you mess up and you make a huge problem/accident and then somebody decides to sue the internet site for facilitating this.
People are already suing sites like chatGPT and others for bad advice so these moderators just do their job and protect the site and its owner. So please know that and don't take any of this personally.
I'm very sorry to hear that. But you can still harm yourself or your neighbors or your coworkers with your ill-advised experiments.
Incandescent light bulbs can obviously not store electrical energy.
This thread is closed now.
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 53 ·
  • · Replies 19 ·
