Do the weak isospins of the w1 and w2 combine?
  • Context: Graduate
  • Thread starter Thread starter QuantumForumUser
    Weak Weak force
The weak isospins of the W1 and W2 bosons combine to form the W+ and W- bosons through the transformation W± = (W1 ± iW2)/√2. In this context, W+ has a weak isospin of +1, while W- has a weak isospin of -1. The weak isospin values remain conserved during interactions, including those with the Higgs field, which affects their weak hypercharge but not the overall electric charge. The W1, W2, and W3 bosons form a weak isospin triplet, with W1 having weak isospin -1, W2 having weak isospin +1, and W3 having weak isospin 0.
  • Understanding of the Glashow-Salam-Weinberg model
  • Familiarity with SU(2) and U(1) gauge groups
  • Knowledge of weak isospin and its conservation
  • Basic concepts of quantum field theory and particle interactions
  • Study the Glashow-Salam-Weinberg model in detail
  • Learn about the role of the Higgs field in electroweak symmetry breaking
  • Research the properties of SU(2) and U(1) gauge theories
  • Explore the implications of weak isospin conservation in particle interactions
Particle physicists, theoretical physicists, and students studying quantum field theory and electroweak interactions will benefit from this discussion.
QuantumForumUser
Do the weak isospins of the w1 and w2 bosons combine as their fields combine?
I don't know what you mean by that. You should look at some textbook how quantum flavor dynamics (the Glashow-Salam-Weinberg model of the electromagnetic and weak interactions) are constructed from the corresponding chiral gauge group ##\mathrm{SU}(2)_{\mathrm{wiso}} \times \mathrm{U}(1)_{\text{Y}}## and "Higgsed" to the ##\mathrm{U}(1)_{\mathrm{em}}## to give the particles and some of the gauge fields (the ##W^{\pm}## and ##Z## bosons) masse without violating the vital chiral local gauge symmetry of the model. A very good book on that is
https://www.amazon.com/dp/3540504966/?tag=pfamazon01-20
What I meant was when the w1 and w2 bosons combine into the w+ and w- bosons through w+ or w- = (w1 -or+ iw2)/sqrt(2). The w+ has weak isospin +1 and the w- has weak isospin -1. So does that mean the weak isospins of the w1 and w2 can be found by rewriting the previously stated transformation (+or- 1= x -or+ iy/sqrt(2))?
Does weak isospin make sense after you do the combination?
Weak isospin (according to Wikipedia: https://en.wikipedia.org/wiki/Weak_isospin) is a conserved quantity. This means that the weak isospin values don't change whether symmetry breaking happens or not.
True, quantum flavor dynamics bases on the local chiral gauge symmetry ##\mathrm{SU}(2)_{\text{wiso}} \times \mathrm{U}(1)_{\text{Y}}##, and this symmetry must not be broken explicitly (and can also not be broken spontaneously):
https://en.wikipedia.org/wiki/Elitzur's_theorem
not the point which i tried to make, but that the W+- are not eigenstates of weak isospin and so they don't have definite eigenvalues..
Try to get what the operator thatgave you the +1 or -1 eigenvalue for the W_i does on them... it transforms the one into the other,
Hint: The SU(2) x U(1) are defined on the "original fields", before introducing the non-vanishing VEV of the Higgs field explicitly. To express the transformation in terms of the "physical" fields (W's, Z, and ##\gamma##) is awful!
According to my book on Electroweak Physics, the w1, w2, and w3 bosons form a weak isospin triplet. This probably means the w1 boson has weak isospin -1, the w2 has weak isospin 1, and the w3 has weak isospin 0. Otherwise, the weak isospins of the w1, w2, and w3 could be eigenvalues of the su(2) Pauli matrices.
I'm not even sure that in unbroken symmetry, weak isospin *can be represented as a scalar* similar to the electric charge. Since it's related to SU(2) symmetry, shouldn't it have two charges? SU(3) has three charges, "colors". SU(2) should have two, no?
I think this is not true. Weak isospin is conserved in interactions. But one of the interactions is with Higgs field. When Higgs field VEV is nonzero, it means that particles interact with it all the time. This changes weak isospin and weak hypercharge of the particles. Only their combination which we call "electric charge" is conserved.
For example, a free electron changes between T3=−1/2,Y=−1 ("left electron") and T3=0,Y=−2 ("right electron"). Only Q=T3+Y/2 stays unchanged.
Actually, w\pm, w3 are the eigenstates of the weak isospin you are referring to ( which is the third component of the weak isospin - T3)
The usefullness of the w1,2,3 basis is that it transforms as a vector in a three dimensional space.
ofirg said:
Actually, w±\pm, w3 are the eigenstates of the weak isospin you are referring to ( which is the third component of the weak isospin - T3)
are you sure that the W± are eigenstates of the weak isospin?
Unless someone knows otherwise, they are eigenstates of the third component of the weak isospin - T3
For example, the electric charge Q=T3+Y ( Y is the hypercharge)
Since Y=0 in this case, Q=T3. So the states with well defined electric charge also have well defined and equal T3.
if the W^{1,2,3} are eigenstates of T^3 with eigenvalues 1,-1,0 respectively, then:
T^3 W^\pm =\pm W^\mp
(in particular the W+/- are more like the ladder operators that you had for the spin).
  • · Replies 23 ·
  • · Replies 18 ·
13K
