Do we lose weight by respiration ? (Losing carbons)
  • Thread starter Thread starter Astra-Rudra
    Weight
The discussion revolves around the concept of weight loss through respiration, specifically examining whether the carbon lost during breathing contributes significantly to overall weight loss. Participants explore the relationship between oxygen intake, carbon dioxide exhalation, and the mass changes associated with these processes.
  • One participant questions whether the weight lost from carbon during a brief period of not digesting food could be quantified.
  • Another participant recounts an anecdote about an experiment where a person measured their mass over 24 hours, noting a small loss attributed to breathing out carbon, but expresses skepticism about the significance of this loss compared to measurement uncertainties.
  • A participant provides a calculation estimating that one could lose just under 1 gram of mass every 5 minutes through respiration, based on various assumptions about air composition and breathing rates.
  • Some participants discuss the process of burning calories, noting that the conversion of carbohydrates and fats into energy produces carbon dioxide and water, with a significant portion of the mass lost as carbon dioxide.
  • There is a suggestion that while there is a measurable difference in weight from respiration, it may be too small to be significant in practical terms.
  • One participant reiterates the idea that the mass lost during calorie burning primarily exits the body as carbon dioxide, framing this as a common understanding.
Participants express varying degrees of skepticism about the significance of weight loss through respiration, with some calculations suggesting a measurable effect while others argue it may be negligible. No consensus is reached regarding the practical implications of these findings.
Participants rely on various assumptions regarding air composition, breathing rates, and metabolic processes, which may affect the accuracy of their claims. The discussion includes speculative elements and acknowledges uncertainties in measurement.
Astra-Rudra
We take in Oxygen (O2) & give Carbon dioxide (CO2) .
Say a guy somehow does not digest any food or fat for 5 min .. So will lose weight equal to all the "C" lost from his body in that 5 min ??
Biology news on Phys.org
I recall having heard this story once (I'm going to abuse your thread to check whether it was actually true :-)) about someone who actually performed the experiment.
He constructed a very accurate scale, and sat on it for 24 hours. All the changes in his mass were accurately recorded: how much food and water he took in, how much he sweat, urinated, ... At the end there was a small amount of mass actually missing from the balance. Allegedly, this was due to the fact of him breathing out more mass than he breathed in (namely, one molecule of C for every oxygen molecule).
I actually wonder whether this story can be true (I suppose that the mass you lose in C-molecules is really, really, REALLY very tiny, possibly smaller than the uncertainties in your other measurements, like sweat excretion).
It does contribute however, so if you wanted to make it really accurate, you would at least have to include this effect (based on an average lung volume, respiration rate, etc) you would be able to estimate this effect.
thx .. i have no interest on losing weight .. lol .. just wanted to know . thx
Did a quick-and-dirty calculation, based on the following data:
* 7,5 litres of air per minute (source, fig 1)
* air weighs 28.97 g/mol (source) of which 20.95 % vol is O2 (source)
* for every 5 molecules of O2 one molecule of C is exhaled (i.e. 20% of the O2 is converted to CO2 - could not find a source for this so it's a wild guess)
* C weighs in at 12,01 grams per mole
* all other properties of the air (non O2-components, density, moistness / saturation) are unchanged
According to my rusty chemistry, punching in this numbers, you lose a little under 1 gram every 5 minutes, as long as you breathe. Since all the calculations are linear, it's easy to adjust for changes (e.g. if you want to convert all the O2, multiply by 5; if you want to double the intake of air volume, multiply by 2, etc.)
Note that 1 gram, is also 1 ml of water. So although the number is not as small as I suspected, you probably lose more weight water every minute (through breathing in dry air and breathing out damp air, as well as sweating) than in C every 5 minutes :P
You are right though, if you wanted to lose weight, this would be a bad way to start :P
Well when we think of losing weight, we think of burning calories. When we convert fuel (carbohydrates and fat) into energy, we produce carbon dioxide and water. For example, for glucose:
C6H12O6 + 6O2 --> 6H2O + 6CO2
Now most of the mass of the water produced comes from oxygen (during oxidative phosphorylation, hydride ions are transferred to oxygen to produce water). So, by this logic, when we are burning calories, most of the mass of the mass of the fuel molecules is going away as carbon dioxide!
There is definitely a difference in the weight of the change, but it is probably too small for measure or significance.
I thought this conclusion was common knowledge. We are in effect, "burning" our food as fuel. Whatever we don't excrete out the back or build fat and proteins with we breathe out as "exhaust".
  • · Replies 16 ·
  • · Replies 20 ·
19K
19K
  • · Replies 16 ·
