pelastration
- 171
- 0
Theoretical models may be very accurate. Sure. Theoretical models are essential, indeed. But theoretical models must stay on logic. And sure ... some theoretical models will make it possible to reverse time. But that doesn't mean it has something to do with reality, or it shows that something is wrong with the semantics.marlon said:Obviously you missed the point, which could have been expected because i said you need to put these time reversal results into the right perspective in physics. Just look at how astrophysics has dealt with black vs. white holes... Non-causal results may not be physical in our minds, yet they are a VALID solution to some theoretical model which has a very high degree of accuracy. This is something totally different then postulating some pet theory...
"Time" is a good example.
Time is a conventional expression of measuring changes in processing, interaction or position.
Time progresses independent from the process itself.
The process can be reversal, but not the time it takes.
If you miss this essential concept you can create many "official" pet theories.
If you use time just as a mathematical parameter then you can do all type of magic things with it.
but I think one has to understand what the technical definition of metaphysics in philosophy to see what he was saying.
