Ozone Concentration: 25 Dobson Units
In summary, the ozone concentration in a particular sample of air would be 25 dobson units if all the air were ozone and it would be 3.127*10^-6 if all the air were not ozone.
pivoxa15
2,255
If the ozone concentration in a particular sample of air were 25 dobson units, what sould this concentration be in:
a)ppm
b) %(v/v)
1 dob = 2.69*10^20 ozone molecules / m^2
http://en.wikipedia.org/wiki/Ozone
The question is asking the concentration whereas dobsons are measured molecules per surface area. How do I go about doing this since the units don't seem to agree? Also for concentration problems, I will need to know the solution which is a mixture of air but what compositions are they? The solute is ozone.
25 dobson units! Don't forget your sun glasses! Normal is about 300 DU of ozone.
Seriously, a dobson unit IS a volume measure. It is like you look a column of air all the way up, removed the ozone and see how large a column the of ozone would be at 1 atm and 0 C. The column of the air compressed down at 1 atm and 0 C would be about 8 kilometers. 25 dobson units would be about .25 mm. From that you can get your concontrations. Not much ozone is there? See:
http://ozonewatch.gsfc.nasa.gov/facts/dobson.html
for a good discussion.
Are we always considering the surface area of the earth? So 25 Dob is .25mm thick of ozone on the surface of the earth? How do you work out the volume? Is it done by integrating from the surface of the Earth to 0.25mm in the radial direction? It seems complicated and imprecise as the radius of the Earth has to be used which could take on many values.
You are making it too hard. Read the article I sent you. You take all the ozone in the atmosphere in a column one meter square and compress standard temp and pressure and it comes out to be .25 mm high in your case. Then you take all the rest of the air in the column and compress it at standard pressure and temp and it comes out to be 8 kilometers high. The ppm is simply .25 mm/8 kilometers... Ok, you are right, the dobson units are one dimensional, but you assign it to an arbitrary column area which makes it a volume.
The dobson units are measured with optics. One looks at the attenuation of light at four frequencies. Two are attenuated by ozone, two that are not. The air column is basically a constant around the World. Yea, I know it varies a bit from place to place, but not by much.
I've seen the rest of the article. One possible error is specifying that the rest of the air composes a column with a base of 1cm^2 that is 8km high. How exact is this 8km?
ppm is atoms of solute per million of atoms in the solution. Let's consider the solute to be .25mm high with a base of 1cm^2. The number of ozone molecules is 6.725*10^17. The solution is 8km high on a base of 1cm^2 but how many molecules in total is in this column? If we assume the concentration to be the same as ozone than all can be worked out as you suggested, 25/(8*10^8) which when converted to ppm is 0.03125.
The answer suggested ppm=0.025
When calculating (%v/v), again I assumed all air were O3 and calculated according its molar mass and got 3.127*10^-6. The answer suggested 2.5*10^-6. So I am a little high and as expected because I have assumed the air to contain all O3 which in reality contain smaller molecules and lighter molecules so my answers were all a bit high. There is also that inaccurate 8km figure. I wonder how they did it.
FAQ: Ozone Concentration: 25 Dobson Units
What is "Ozone Concentration: 25 Dobson Units"?
"Ozone Concentration: 25 Dobson Units" refers to the measurement of the total amount of ozone gas present in a column of the Earth's atmosphere. 25 Dobson Units is equivalent to a layer of ozone 1 millimeter thick at standard temperature and pressure.
How is "Ozone Concentration: 25 Dobson Units" measured?
"Ozone Concentration: 25 Dobson Units" is typically measured using satellite instruments such as the Total Ozone Mapping Spectrometer (TOMS) or the Ozone Monitoring Instrument (OMI). These instruments use ultraviolet light to measure the amount of ozone in the atmosphere.
What is the significance of "Ozone Concentration: 25 Dobson Units"?
Ozone is an important gas in the Earth's atmosphere as it helps to protect us from harmful ultraviolet radiation from the sun. A measurement of 25 Dobson Units indicates a healthy level of ozone in the atmosphere, which is essential for protecting life on Earth.
How does "Ozone Concentration: 25 Dobson Units" vary around the world?
The amount of ozone in the atmosphere can vary significantly depending on factors such as altitude, latitude, and weather patterns. Generally, areas closer to the equator tend to have higher ozone concentrations, while polar regions can have lower concentrations.
What are the potential impacts of a change in "Ozone Concentration: 25 Dobson Units"?
A decrease in ozone concentrations can lead to increased levels of harmful UV radiation reaching the Earth's surface, which can have negative impacts on human health and the environment. On the other hand, an increase in ozone concentrations can contribute to climate change and other environmental issues. Therefore, it is important to monitor and maintain a healthy level of ozone in the atmosphere.
