Does a bullet fired with a clockwise spin travel faster or slower
  • Context: High School
  • Thread starter Thread starter rasanders22
    Bullet Spin Travel
The discussion revolves around the effects of a bullet's spin direction (clockwise vs. counter-clockwise) on its speed and trajectory. Participants explore theoretical implications, energy dynamics, and the role of rifling in bullet performance, touching on concepts of aerodynamics and stability in flight.
  • Some participants question whether there is a difference in speed between bullets with clockwise and counter-clockwise spins, suggesting that the spin direction may not affect speed at all.
  • Others propose that a spinning bullet could travel faster, slower, or at the same speed as a non-spinning bullet, depending on the energy distribution between rotational and translational motion.
  • A few participants argue that rifling improves accuracy and range by stabilizing the bullet's flight path, while also noting that a tumbling bullet would be less aerodynamic.
  • Some contributions mention the Magnus effect, which could influence the bullet's trajectory in the presence of crosswinds, but do not clarify its impact on speed.
  • There are discussions about the aerodynamic advantages of modern bullet profiles compared to round balls, with some questioning whether outdated assumptions about bullet design still hold true.
  • One participant reflects on personal experiences with air rifles, contrasting the performance of rifled versus non-rifled barrels.
Participants express differing views on the impact of spin direction on bullet speed and trajectory. There is no consensus on whether a spinning bullet travels faster, slower, or at the same speed as a non-spinning bullet, and the discussion remains unresolved.
Some arguments depend on assumptions about energy transfer and aerodynamic effects, which are not fully explored or agreed upon. The discussion includes various perspectives on the role of rifling and bullet design, but lacks definitive conclusions.
  • #31
A big NO on that one and, of course I agree on that with you that, spinning, per se, is not likely to affect air resistance (although the surface speed of the bullet would be a bit higher; I don't know what effect this could have on the drag as it could increase the volume of turbulent air around the bullet, perhaps.)
I am just pointing our that the consequence of not spinning is that tumbling will occur. Spinning will "resist" the tumbling but I don't see that as "resisting air resistance".
  • #32
Can someone explain how spinning would give the bullet Gyroscopic force?
Even spacecraft 's spin to maintain course. The reason for both the bullet and spacecraft might be same.
I don't understand how spinning would give it "force".
  • #33
jarednjames said:
Yes, but people seem to confuse the ability of a small bullet going faster with it's ability to "stop" someone. One of the reasons for hollow point 9mm ammo is to give greater stopping power to the weapon.
Obviously there is some debate between energy and stopping power possessed by a bullet. Now I am no expert on firearms or ammunition, but here is my take:
A smaller bullet my be able to be fired with a greater velocity thus increasing its kinetic energy greatly since KE=(1/2)mv^2. But if a small bullet encounters less resistance while traveling through the target then it will leave the target with some velocity left. So the energy transferred to the target is equal to the difference in kinetic energy of bullet (neglecting heat, etc.).
Now a larger bullet may carry less initial kinetic energy, but experience enough resistance to stop somewhere in the target (or at least come out with a much lower velocity). Because of this the change in KE and thus energy transferred will be greater.
Of course this is not taking into effect the tumbling of the bullet within the target. If a small fast bullet tumbles withing the target then its velocity will greatly slowed or stopped causing much greater stopping power. I've heard of those little 22 caliber bullets people like to make fun of doing a lot of damage because of this. They enter the target tumble around and don't exit. So in a pure physical sense stopping power is only related to the amount of energy transfer. Taking into account what vitals are hit and bleed out times is an entire different story. This is only talking about the stopping force felt.
  • #34
Direction of twist is at the whim of the manufacturer. Harry Pope built some of the finest target barrels ever, and his preference was for left hand twist. The direction of twist was not the source of the accuracy, though. His rifling featured wide shallow grooves and narrow lands that minimized friction while retaining control. Plus he fitted "false muzzles" to the ends of his target barrels to facilitate muzzle loading of the bullets separately from the cartridges. Muzzle-loading soft lead bullets prevented the burrs and lack of uniformity on the base that resulted from breech-loading.
He also used "gain twist" rifling in which the rifling near the breech twisted more slowly than the rifling near the muzzle. He claimed that having a shallower twist near the breech allowed the bullet to accelerate faster initially, and the steeper twist at the muzzle imparted an accelerated spin to the bullet for gyroscopic stability. Given the impressive target scores racked up by users of his barrels, it seems that he knew exactly what he was talking about.
  • #35
What is "gyroscopic force"? Do they mean gyroscopic moment? Spin will tend to keep the bullet orientated along the direction of the spin axis. It will precess a little but not significantly before it has hit its target.
Google Gyroscope and Angular Momentum for more info and some animations / explanations.
  • #36
Hollow point bullets are designed to mushroom and/or fragment on impact--therefore more 'stopping power'.
Mushroomed 9mm.
  • #37
jarednjames said:
I fully understand that, but that doesn't mean it reduces air resistance.
The air resistance a spinning bullet undergoes is equal to that of a non-spinning bullet. It's not until the bullet is tumbling that this changes. So the gyroscopic forces prevent the tumbling occurring.
However, the air resistance each encounters up to that point is identical. It's only that one reacts and the other is able to resist.
I'm not seeing it as reducing air resistance, more that it has an increased ability to withstand it.
The spinning stabilizes the bullet, because it is stabilized (not shaking, vibrating, tumbling, zig-zagging, etc.) it cuts a path through the air that offers it less air resistance.
  • #38
A larger bullet has more stopping power. There's no debate on that.
A .45 can stop a person more effectively than a 9mm. And a .50 more effectively than that.
Remember, stopping power is not the same as ability to kill or damage done.
  • #39
No, stopping power is determined by how much energy is transferred from the projectile to the target. It is affected by both the mass and velocity of the bullet, as well as to how it behaves when it strikes the target.
  • #40
There is no consensus regarding energy transfer being responsible for stopping power. Please read the articles on stopping power, starting with wiki:
http://en.wikipedia.org/wiki/Stopping_power
Stopping power is a colloquial term used to describe the ability of a firearm or other weapon to cause a penetrating ballistic injury to a target, human or animal, sufficient to incapacitate the target where it stands.
This is the important point here. It is the ability of the bullet to "stop" the target.
If you read on, they mention energy transfer and a few other effects but make it clear that not everyone agrees on which is important and apply to stopping power. Energy transfer is only one hypothesis of stopping power and not well agreed upon.
For a start, momentum plays a far larger part than energy transfer when it comes to stopping something.
A 1kg bullet traveling at 100m/s has a KE of 0.5*1*1002 = 5000J
A 10kg bullet traveling at 50m/s has a KE of 0.5*10*502 = 2500J
A 1kg bullet traveling at 100m/s has a momentum of 1*100 = 100kg*m/s
A 10kg bullet traveling at 50m/s has a momentum of 10*50 = 5000kg*m/s
Assuming it hits you square in the chest, the smaller object imparts twice the energy of the larger, but the momentum conservation is far more in favour of the large object. Think of the above example like tennis ball and bowling ball. A 100mph tennis ball to the leg will bounce off (hurt like hell but bounce off none the less). A 20mph bowling ball to the leg will knock you off your feet and also has the potential to break it.
  • #41
Aren't you describing Shells, rather than Bullets" Plenty of personal firearms have a mass less than 10kg!
For a gun held by a person, the momentum available for the projectile is limited by the amount that will knock him over backwards- in fact a lot less. This can hardly significantly "stop" anyone's forward motion by momentum transfer.
Of course, I know that a good bigun beats a good littleun but as to the Physics involved? That's another question. I suspect it may be something to do with the effect of a hefty shockwave on the nerves of the target, rather than a but of mechanics. Once your knees have buckled, you are, effectively Stopped.
  • #42
It was an example with deliberately skewed numbers to demonstrate a point. I would have thought that would have been perfectly clear. Or are people here under the impression I believe the average bullet mass is from 1 to 10kg? I take offense to that.
Please read the article I linked to on stopping power. You aren't necessarily stopping a person dead (bullet hits, they literally stop - I have never said this). Stopping power is only incapacitating them. A 9mm to the shoulder and you may be able to continue coming at me with a knife, whereas a .45 is likely to drop you. Whether people here like it or not, a bigger bullet has more stopping power, despite moving slower and having a lower KE. Moving slower means it has lower KE - so even if 100% of this is transferred to the target, the smaller bullet still imparts more - but the larger bullet still has more stopping power.
Shockwaves on the nerves are only another hypothesis as per the article.
Precisely. And that's what stopping power is. The tennis ball may do a fair bit of damage so far as hitting me and causing severe bruising, but it doesn't necessarily stop me immediately.
The only key factor I'm seeing is the bullets momentum, and more importantly its ability to transfer that to the target causing damage. A small bullet is far more likely to pass through you.
  • #43
Yes.
We're into one of those topics that are really outside the realms of Physics. Unfortunately, people seem to want to quantify things that are unquantifiable in simple engineering terms.
A proper Physicist should take a step backwards here, I think. Fools rush in. . .
Btw, if a tennis ball hit me hard, I'd stop and go home. Am I just weedy?
  • #44
sophiecentaur said:
Yes.
I don't see why it's outside of physics.
Simple, certainly not. It's an exceptionally complex subject.
I'm not trying to explain it, but simply point out how people can't make blanket statements and try to explain it with only "it's the energy transfer".
My post is only to demonstrate the importance of momentum when looking at the issue and not writing it off to only energy.
  • #45
If a tennis ball hit me at 100mph, I'd probably keel over. But I'd be damn glad that it wasn't a bowling ball.
  • #46
I say it's outside Physics because all the interesting considerations (once you have calculated the Momentum and K.E. - School book work, actually) are Physiological and specific to anatomy or even Psychology.
I can't really attach as much importance to Momentum as I do to Energy where a bullet hits a human body because I would think that the actual damage done relates more to Energy. There are grisly details like the shape / area of the bullet as it goes through the body which would affect how 'usefully' the bullet's energy is transferred (matching the energy source to the load, if you like). But there may well be momentum transfer issues where impact with bones is involved.
That reminds me - we're having steak for dinner.
  • #47
How about a 45 vs a 357 magnum? Got the flu here, really bored. Chuckle.
DC
  • #48
Get well soon. Plenty of sleep and liquids.
  • · Replies 23 ·
  • · Replies 28 ·
  • · Replies 236 ·
18K
  • · Replies 29 ·
