Does a changing electric field have momentum?
4 replies · 4K views · last reply
WaveObserver
Is it fair to say that any changing electric field (hence electrodynamic) has momentum?
No it isn't. A changing E-field alone does not carry momentum. You have to consider with it the induced B-field and the Poynting vector.
The momentum density stored in the electromagnetic field is given by:
[tex]\rho_{EM}=\mu_0\epsilon_0 \vec{S}=\mu_0\epsilon_0 (\vec{E}\times \vec{B})[/tex]
There's a few pieces of information we can gain from this equation:
1. Momentum can only be stored in a field that has non zero E and B.
2. The fields do not need to be time varying. Even a static field can have momentum, as long as its Poynting vector is not zero.
Thank you very much GO1.
So in the example I had the Poynting vector would be non zero. But that is not the case for all electric fields and all conditions. If either E or B are zero then you have no momentum.
GO1 do you use a tool for creating latex equations or are you just entering the codes?
Your welcome!
Physics Forums, being the great place that it is, has Latex built in:
https://www.physicsforums.com/showthread.php?t=386951
You can also click on the [itex]\Sigma[/itex] box on the reply to page to pull up a handy latex code library.
