Does Temperature Affect Current Flow?
The discussion revolves around the relationship between temperature and current flow in electrical circuits, specifically whether current varies as temperature changes during operation. Participants are exploring the implications of temperature on resistance and conductivity.
  • Some participants attempt to assert that current does not change with temperature, while others question this assumption by linking current to resistance, which is affected by temperature. There is a discussion about the role of conductivity and resistivity in this context.
The conversation is ongoing, with participants exploring different interpretations of how temperature influences current through its effect on resistance and conductivity. Some guidance has been offered regarding the relationship between these concepts, but no consensus has been reached.
Participants note the need for clarification on the specific context of the current being discussed, particularly whether it pertains to a constant-current source or another scenario.
randomss444
Is current different at different temperatures, as it heats up to its working temperature?
My answer would be no because current does not change.
Is that correct?
Is that correct?
Temperature changes resistance of materials.
Alright so that means that current is effected by temperature because in order to find current you need to know resistance and because resistance is effected by temperature. Correct?
Yeah. The actual parameter that changes with temperature is called conductivity or resistivity (they are reciprocals of each other). The less temperature you have, the less kinetic energy you have. So the electrons, when a voltage is applied, move straight to where they want to go easier and without interference as you approach absolute zero temperature. However, when you add the kinetic energy (the heat), the electrons can no longer smoothly move to where the voltage attracts them to. Instead, they bounce around crazily, often in the opposite direction as the voltage demands, but with an overall "drift" toward the "right" direction. This effect becomes greater and greater as you increase the temperature.
[tex]\sigma = q(n\mu_n + p \mu_p)[/tex]
where sigma is conductivity and the mu_n and mu_p are electron and hole mobilities respectively. The mobility is a numerical estimate that contains the effects that I described earlier about temperature. n and p are the electron and hole concentrations. q is the charge of a proton.
In case you did not know, resistance is directly proportional to resistivity and inversely proportional to its reciprocal, conductivity.
I can't believe that is the full problem statement. The current of what? If you mean something that is connected to a constant-current source, then the current would be the same at different temperatures.
  • · Replies 33 ·
  • · Replies 64 ·
