Does the Cheerio Effect Occur in Zero-Gravity?
  • Thread starter Thread starter GRB 080319B
The Cheerio effect, which describes how small objects can cluster on the surface of a liquid due to surface tension, does not occur in zero gravity. In a zero-G environment, liquids do not form stable surfaces but instead create floating bubbles. These bubbles can attract small objects placed on them, but the dynamics differ significantly from those on Earth. The absence of gravity alters the behavior of liquids, preventing the typical floating phenomenon. Overall, the principles governing the Cheerio effect are not applicable in zero-G conditions.
GRB 080319B
Does the http://en.wikipedia.org/wiki/Cheerio_effect" happen in zero-G?
I would say that you can't float on top of a liquid in zero-g, no.
In zero-g, liquids will form into floating bubbles. You could place two small objects on the surface of such a bubble and they would probably attract each other.
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
