Does the expansion of air affect the overall volume increase of a glass stopper?
  • Thread starter Thread starter zorro
    Expansion Glass
The discussion centers on the thermal expansion of a glass stopper with a hollow section. It explores whether to consider the expansion of both the glass and the air within the hollow when calculating the increase in volume due to rising temperatures. One viewpoint suggests that the hollow expands as if filled with glass, leading to a specific volume increase. However, the counterargument emphasizes that including the air's expansion could result in a greater final volume. This highlights the complexity of thermal expansion in materials and the importance of considering all components involved.
zorro
Suppose there is a glass stopper with a hollow in it. If the ambient temperature rises the volume of the hollow(say 1cm3 initially) also rises. To find out the increase in volume, do we have to take into account the expansion of air along with the expansion of glass?
Unconstrained thermal expansion is stress-free. So you can imagine that a glass piece fits into the hollow and expands stress-free; therefore, the hollow expands as if it were filled with glass, not air. Does this help?
The question does not say about the glass fitting in a hollow. There is a hollow in the glass stopper.
Read my answer again: imagine that the hollow part is filled with glass. It would expand the same amount.
Okay, I get you now.
But is that not loss of generality? If we consider some amount of air to be present in the hollow, both of them will expand which can lead to a different final volume (greater) compared to your case.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
