Does the Function Have an Inverse? A Theorem for Proving Inverse Functions
The discussion centers on proving that the function f(x) = (ax+b)/(cx+d) is either constant or has an inverse. Participants clarify the importance of bijective properties, noting that a function must be both injective (one-to-one) and surjective (onto) to possess an inverse. A cubic function example illustrates that surjectivity does not imply injectivity, highlighting the need for both properties. The original function's parameters are examined, revealing that if both a and b are zero, the function becomes constant and lacks an inverse. Ultimately, the conversation emphasizes understanding the conditions under which the function can be classified as either constant or possessing an inverse.
iloveannaw
Given the function
f(x) = \frac{ax+b}{cx+d}
where f: \mathbb{R} \backslash \left\{ \frac{-d}{c} \right\} \rightarrow \mathbb{R}
show that f is either a constant or has an inverse function.
I can see why this would be true. If a function takes all real numbers and returns all real numbers then it could either be a multiplying constant or have an inverse, e.g. x2
wouldn't work here because it only returns values greater than zero.
My question is is there a theorem or lemma or something that can help me prove this?
thanks
ah, i just found out about the bijective requirements for inverse functions – sorry we didn't cover this in class.
but I'm a bit confused injection and surjection seem quite the same. Isn't it enough to show that the function is one-to-one??
No, "injective" and "surjective" are not the same. For example, the cubic function f(x)= (x- a)(x- b)(x- c) is surjective- given any number y, there exist an x such that f(x)= y. That is true because \lim_{x\to\infty}f(x)= \infty, \lim_{x\to-\infty} f(x)= -\infty and f is continuous.
But f is NOT injective: f(a)= f(b)= f(c).
Hi, thanks for the reply :smile:
Looking more at the given function i can show that it is indeed one-to-one. As to whether it is surjective I'm not really sure what my answer is telling me:
f\left(x\right) = \frac{ax+b}{cx+d} = \xi
ax+b = cx\xi+d\xi
x = \frac{d\xi - b}{a - c\xi}
where \xi, a, b, c, d \in \mathbb{R}. The question states that
cd \neq 0, meaning that either a or b could be zero. If we say:
a = b = 0, then
x = \frac{-d}{c}, which is 'not allowed' as the original set excludes that term. What does this mean?
thanks
If a and b are both 0 then the original function is f(x)= 0, for all x, which has no inverse. Remember, the problem was to show that either f is a constant or has an inverse.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
