Does the limit converge or diverge
  • Thread starter Thread starter kuczmama
    Limit
kuczmama
infinity
Ʃ \frac{ln(n)}{n\sqrt{n}}
n=1
I think that I need to use either the limit comparison test or the ratio test.
After listing all the terms I found out that the function was positive and decreasing, and that the terms approached 0. However when I used the limit comparison test or the root test I keep on getting an answer of infinity or 0, which is inconclusive. So I don't know how else to approach the problem. Is there something easy that I am overlooking. Thanks.
kuczmama said:
infinity
n=1
Show us what you tried for the limit comparison test. I agree that the ratio test would not be conclusive.
I think the best test to use is the ratio test:
If there exists a constant C < 1 such that |an+1/an|<C for all sufficiently large n, then ∑an converges absolutely.
Have you thought about the integral test?
for the limit comparison test I tried a bunch of different comparisons. I said as lim n-> infinity of
lim n→∞. of (ln(n)/(nsqrt(n))/(1/n^5/4).That didnt give me any help. Then I tried comparing it to 1/n^1/4. Then I tried comparing it to a bunch of other stuff but nothing seemed to work. I can't figure out what to do
Also I never thought about the integral test. I will try that
@kuczmama: Don't use the X2 key inside tex brackets. Right click on this to see how to do exponents:
n^{\frac 3 2}
I got that the integral converges to 4. I guess that this means the sum also converges. Thanks a lot guys!
