- 19,385
- 15,623
pallidin said:Not so fast... that a REALLY bad analogy.
I'll leave it to you to understand why.
I'm confident that I DO understand ... why it is a good analogy. Your concept about current is just mistaken.
Drakkith said:It seems perfectly fine for an analogy to me. After all, it's just an analogy. The force you apply to the pedals is the voltage, the chain is the current, the resistance is the hill. Seems perfectly fine to me. It ain't perfect, but it works.
DaveC426913 said:Pallidin may not be right but the best way to put a nail in the coffin of his claims is for some expert to simply state what is happening.
So: When electricity in a circuit is converted to another form, (say light in a lightbulb) what "happens" to the energy in the circuit?
OK, there is no reduction in current. Is there a reduction in voltage?
What is the net difference between a circuit containing a light that's off and an identical circuit with a light that's on?
sophiecentaur said:Easy. You can see one but you can't see the other. Boom boom.
pallidin said:Hopefully not in opposition of PF rules, I do like posing "devil advocate" comments to more thoroughly understand an OP's question/position as well as, more importantly, incite expert response.
I have done this a number of times, and have found it quite useful in "zero-response" questions.
I apologize to all if this has been inappropriate.
gkangelexa said:Current and charge do not increase or decrease or get used up when going through a wire or other device. The amount of charge that goes in at one end comes out at the other end.
Where does the current go then, when I run electrical devices? If it is not used up when I turn on a light bulb or use the TV, where does it go?
To compare an electric field across a conductor with a gravitational field of a waterfall is not bad at all. In this case you can compare falling water with electrons, with the exception that electrons will not continuously accelerate but rather have a terminal velocity like raindrops falling through the air. This terminal velocity is due to factors like the ones mentioned in post #38.Fun Value said:The electrical device is like a waterfall. At the top of the waterfall is the positive side of the battery or battery eliminator and the bottom is like the negative side. The positive side of the outlet is like the top of the water fall. The negative side is like the bottom of the waterfall. The pool at the bottom of the waterfall is like the negative side of the electrical device and like the negative terminal of the battery or battery eliminator.
Antiphon said:The actual movement of charges in a wire is very slow as has been pointed out. For AC power distribution at 60 Hz, essentially the charges go nowhere. If you plug in you alarm clock now, ten years from now the same electrons will probably reside in the plug.
The energy is not transmitted by the electrons pushing up against one another. It is transmitted through the fields (E, H) in the air around the wires and can be calculated via the Poynting vector which is zero in the wire but not in the space around it.
Drakkith said:This doesn't make any sense to me. The force doesn't just magically get into the air and wire, it has to have charges carry it. If you apply a potential to the conductor on one end, it influences the electrons so that the average movement is in net direction. Each electron only has to move a very very small distance, but the voltage or emf or whatever travels down the conductor very quickly.
Antiphon said:Does a microwave heating your food make sense? How about the sun warming your hand? No wires.
The wires are only there to guide the fields to where you want them to be. The force is in the air, just not magically, rather Maxwell-ly.
Drakkith said:What? I wasn't referring to photons, I was talking about the emf through a conductor. Can you point to anything incorrect in my post or not?
This is incorrect. See the sunlight.Drakkith said:This doesn't make any sense to me. The force doesn't just magically get into the air and wire, it has to have charges carry it.
This is correct but it's missing the true mechanism of power flowing. The flow of power down a pair of wires is not even a little bit analogous to sound or pressure in a pipe.If you apply a potential to the conductor on one end, it influences the electrons so that the average movement is in net direction. Each electron only has to move a very very small distance, but the voltage or emf or whatever travels down the conductor very quickly.
Drakkith said:How can the electrons not be pushing other electrons? How else would the emf or voltage or whatever move down the line?
gkangelexa said:Where does the current go then, when I run electrical devices? If it is not used up when I turn on a light bulb or use the TV, where does it go?
SteamKing said:It's called a ground for a reason.
gkangelexa said:So then what do electric companies charge you for?
What are you trying to say? Are you suggesting that electrical power is really mechanical power like water? That's not at all intended to be implied by the analogy. It's an analogy.Per Oni said:Hey folks, those of you who think electrical power is transported by electrons through a wire analogous to water in a water hose, please consider the following:
We know the drift speed of conducting electrons is very low. Say Vd=10^-3 (in fact it’s even a little below this value). Say I want to drive a motor of a modest 1KW dc with 1Amp. Please work out first of all the force required in the connecting cable to be able to develop such a power with this velocity. (A touch high?)
Next look up what size cable is needed for a 1 amp current . In this case, for copper wire the current density can be ~ 10^7 /M^2. From calculated force and wire surface area, a pressure can be calculated. ( A bit steep?)
This example is by no means extreme. Please use instead real existing values for a 100W light bulb in your own home. DO IT!
russ_watters said:What are you trying to say? Are you suggesting that electrical power is really mechanical power like water? That's not at all intended to be implied by the analogy. It's an analogy.
Drak, there simply is no electric force pushing current down the wire. The current, once established, moves under it's own momentum (contained NOT in the electron mass but in the magnetic field.)
