Does The Range Equation Work for Complementary Angles?
  • Thread starter Thread starter slr20042003
    Angles Range Work
The range equation indeed provides two solutions for complementary angles, except in the case of maximum range, which is uniquely 45°. When solving for an angle given a specific range, both θ and 90°-θ are valid solutions, unless dealing with an inclined plane. In scenarios involving elevation changes, the solutions adjust to account for the incline angle. While both solutions exist mathematically, practical considerations may favor one angle over the other due to factors like drag and ease of execution. Understanding these principles helps illustrate the real-world applications of physics concepts.
slr20042003
I am a physics teacher and am wondering something about the range equation. Wouldn't that equation work for complementary angles each time? The author of our book has us solving for one angle but shouldn't you solve for two?
If given range, you are solving for angle, yes. You should get two solutions or none. The only exception is maximum range, which has precisely one solution, which is 45°.
In general, if θ is a solution to a range equation at given range, then so is 90°-θ.
Unless, of course, it is an inclined plane. If the plane is at angle α above horizontal in the downrange direction, the solutions will be θ and π/2-θ+α.
I never realized that range with elevation change formula can have such an elegant form when change of elevation is expressed as an incline angle. Good to know.
In real setups, the steeper solution is often impractical, as it gives more drag (and might be more difficult to achieve).
Depends on what you are doing with it. There is a demo I used to show to undergrads in the physics lab. Ask one student to set up a plastic cup 4-6 meters from a spring-loaded cannon (max range ~7m), measure the distance to the cannon, compute angle, shoot a ball bearing into the cup. In that case, you want to go with steeper angle, because it gives you a bigger cross-section to hit and is less likely to knock the cup over. Really drives the point across that simple physics that they learn can actually be used to predict something practical with such precision.
Point is, there are two solutions. Whether one is more practical than the other is a separate issue that has nothing to do with problem itself.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
