Does the spring constant of rubber affect the rate at which it cools?
The discussion centers on whether the spring constant of rubber influences its cooling rate, specifically the cooling constant 'k'. Participants express skepticism about a direct relationship, noting that both properties may correlate with rubber's density but lack a physical connection. Hysteresis is mentioned as a potential factor, though its relevance remains unclear. The spring constant is defined only within a limited range, complicating any potential relationship with thermal properties. Overall, there is a consensus that no established link exists between the spring constant and cooling rate, suggesting further investigation may not be fruitful.
namitakn
Does the spring constant of a piece of rubber affect its rate of cooling constant 'k' ?
1) Is there any formula, any proven relationship?
2) If there isn't, would investigating it make any sense? Or would it end up being a waste of time as the two variables are totally unrelated?
Is there a possibility of a relationship between the two.
3)I am not sure, but when I asked this to someone, I was told to read something about hysteresis (don't know if I spelt it right!). What is it? I couldn't understand anything I read about it? And could it possibly answer my question?
I don't see any reason to expect any dependence. Both might be correlated with the density of rubber, but that is like asking for a correlation with the market price... sure, you will find some, but not because of a physical relation. In addition, spring constants for rubber are not well-defined, and a material property, whereas k depends on the shape and size of your material.
Okay, so ...
yes, I know that the spring constant for a piece rubber is defined only over a very small range, it reaches elastic limit very soon. Therefore, the original s.constant will be considered.
Is there any other variable that has a closer connection with spring constant that I could investigate?
The k factor in the Newton cooling equation and k factor denoting spring constant are coincidentally using the same letter for representation. As far as I know, there is no relationship between the two properties. Like most formulas, one can use different letters to represent different quantities, as long as it is understood which quantity goes with which letter.
It seems a plausible speculation (at least to somebody like me who knows a bit about continuum mechanics and heat transfer but nothing much about chemistry) that the elastic behavior and thermal properties of rubber would both be related to its behaviour at the molecular level, i.e. the way the long chain molecules "uncoil", and/or are intertwined with each other.
But I have no idea whether this has already been studied, or what the conclusions were if it has been studied.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
