Does the Sun's Gravitational Effect Influence the Calculation of Star Distances?
  • Thread starter Thread starter luiscar
    Star
The discussion centers on whether the Sun's gravitational influence affects the calculation of star distances using the parallax method. It is suggested that the curvature of space due to the Sun could lead to underestimating the angle difference in measurements, potentially resulting in inaccurate distance calculations. While some argue that the effect is negligible, others believe that even slight influences over long distances could accumulate to significant errors. The accuracy of parallax measurements, particularly those from the HIPPARCOS mission, has accounted for relativistic corrections. Ultimately, the conversation highlights the complexity of measuring cosmic distances and the importance of considering all potential influences.
luiscar
Considering the effects of the relativity theory in terms of the curvation of space, I am wondering if for the calculation of the distance to the stars using the parallax method (below 100ly), the effect that the sun is creating a deformation in the solar system is taken into consideration.
The escape velocity of the solar system from the Earth orbit is around 42Km/s. I do not know how to calculate how this may affect a light ray traveling from outside the solar system and arriving at the Earth orbit, but for sure it has an effect.
Furthermore, imagine the following:
1. There is a star 4.2ly away from the sun
2. It is located in a direction perpendicular to the Earth diameter
If we mesure the angle formed between the star, the eart and the sun at the beginning and the we measure the angle six months later (consider the 90ºeffect), the values we would obtain would be:
89º 59'59.18''
90º 0'0.52''
That means that the angle difference is 0.0005%
42Km/s / 300000Km/s = 0.014%
So actually, the sun effect may affect a lot.
So my point is that if the sun is curving the lightpath, maybe we are mesuring a more little angle difference than which is actually, and , therefore saying that the star distance is more than which actually is.
Any ideas on how the light path is affected when traveling through the solar system?
Astronomy news on Phys.org
"Any ideas on how the light path is affected when traveling through the solar system?"
Almost none at all, or at least too small to be measurable. A similar question was posted before, and I don't remember the website citation, but any effect on a parallax measurement would be, at most, just one part in many billions. The light is not passing very near our single big-body (Sun) as in the 1919 eclipse experiment. In fact, since we measure from Earth, we will always be at one AU. The parallax measurements should be as accurate as our instruments are.
I've never looked into the exact details of how parallax range-finding is done, but I know how I would do it:
I would want to get the widest parallax angle I could. Therefore, I would draw a straight line from the distant object under observation to the sun. I would try to make my measurements when I am as far away from that line as possible. So, drying in a straight line through the sun that is at a 90o angle to the original line, I would take my measurements as Earth passed through this second line. I think it is reasonable to guess that this is how astronomers make their measurements.
As you probably know, the curvature of light that results from our Sun's gravitational field is so slight that we have to wait for a solar eclipse to see light that has passed close enough to the sun that the effect is measurable at all. But using the above method for parallax range-finding, one would be observing the light that has never passed close Earth than 1 astronomical unit from the sun.
Well, you say slight. I do agree, it is slight, but nevertheless, it lasts for 1 hour-light (1080MMKm). At this distance, the escape velocity is still a big number (around 15Km/s over the Earth's ground escape velocity) and you have been at light speed for 1h
You know slight + long time = some effect.
If you calculate the effect that would have in the trigonometry of a "Galileo spaceship" going at c.
My calculations say that we would be sayng that a star is at 4ly when it is actually at 1ly.
HIPPARCOS, the most accurate set of parallax measurements made to date (at least, in the optical band), did take relativistic corrections into account.
See Volume 1 of the report; it's online:
http://astro.estec.esa.nl/Hipparcos/CATALOGUE_VOL1/catalog_vol1.html
I don't recall which section covers the relativistic correction, probably 1.2.
See: http://instruct1.cit.cornell.edu/courses/astro101/lec14.htm
about 8/10ths down the page. Notice the distances are in parsecs (3.26ly).
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
