Does W(2,-1) Lie on UV's Perpendicular Bisector?
  • Thread starter Thread starter tamilan
    Perpendicular
To determine if the point W(2,-1) lies on the perpendicular bisector of line segment UV with endpoints U(3,5) and V(-3,-1), first find the midpoint of UV and the slope of the line connecting U and V. The midpoint is calculated as the average of the coordinates of U and V. Next, the slope of UV is determined, and the slope of the perpendicular bisector is the negative reciprocal of this slope. Finally, check if the slope between W and the midpoint equals the slope of the perpendicular bisector to confirm if W lies on it.
tamilan
Determine whether the point W(2,-1) lies on the perpendicular bisector of line segment UV, endpoints U(3,5) and V(-3,-1). Explain and justify your answer.
I can't figure it out, if someone could, it would be a pleasure! (it is a grade 10 question)
I probably would start by graphing the information given. Then determine equation for the line going through U and V using the coodinates they gave you. You could find the perpendicular bisector by first finding the midpoint between U and V (see your text for description of finding midpoints) and using the slope of the line thru U and V, transform the slope as I pointed out in your post
can you please work out the question for me... i do not understand what your trying to tell me? I am not very good at math either, if u are generous enough to provide the steps, and not the answers - it would help me understand..
ex. Step #1:
Forula: (y2-y1)/2+(x2-x1)/2 *(1,5) and (-1,6)
then i will work out it, then tell me how to step 2 .. this will be very useful.. thank you!
And you will have learned nothing except how to plug numbers into a formula that you do not understand!
1. Find the midpoint of the line segment between (3,5) and (-3,-1).
2. Find the slope of the line through the points (3, 5) and (-3,-1)
3. Find the slope of the line through (2,-1) and the point you found in (1).
4. What is the product of those two slopes? How does that tell you whether the lines are perpendicular or not? (Your textbook has information about the slopes of parallel lines and perpendicular lines.)
