Does Water Pressure Change Inside a Cave at the Bottom of the Ocean?
The discussion revolves around the nature of water pressure in various scenarios, particularly focusing on whether water pressure changes inside a cave at the bottom of the ocean compared to outside it, and how pressure behaves in different container shapes. Participants explore theoretical and practical implications of water pressure, including its dependence on the weight of the water column above a point and the effects of structural elements like shelves or container shapes.
  • Some participants assert that water pressure is solely a function of the weight of the water column above a point, suggesting that pressure under a shelf in a tank would not be halved if the shelf does not extend completely across.
  • Others argue that the pressure under a shelf or in a cave remains the same as at the same depth outside of it, emphasizing that pressure is transmitted uniformly in fluids.
  • A participant questions why pressure would not be transferred through a shelf or cave, seeking clarification on the mechanics of pressure distribution.
  • There is a discussion about whether pressure would be different in a triangular container, with some suggesting that pressure is greater where the water height is greater, while others maintain that pressure is uniform across the base of the container.
  • Some participants mention that in a closed container, pressure can build up until equilibrium is reached, complicating the understanding of pressure solely as a function of water weight.
  • One participant notes that gas behaves similarly to fluids in terms of pressure distribution, suggesting a broader principle of fluid dynamics.
Participants express differing views on how water pressure behaves under various conditions, with no clear consensus reached regarding the effects of structural elements on pressure or the behavior of pressure in different container shapes.
Participants highlight that pressure distribution may be influenced by the shape of the container and the presence of structural elements, but the exact implications of these factors remain unresolved. There is also uncertainty about the interaction between pressure in closed systems and the principles governing fluid dynamics.
jackrabbit
I understand that water pressure is solely a function of the weight of the water column (plus atmospheric pressure) above a given point in the body of water. Ignoring atmospheric pressure, assume that a water column above a given point at the bottom of a tank of water is 10 pounds. Assume that, half way up the side of the tank, a rigid shelf is attached to the wall that extends a foot or so horizontally out into the water. (Assume that the tank is several feet wide, so that the shelf only extends part way across). Is the water pressure at the bottom of the tank under the shelf only 5 pounds? And as soon as you step out from under the shelf, is the pressure back to 10 pounds? Or is the calculation more complicated than that, and if so, why?
Stated differently, if you swim into a cave at the bottom of the ocean, is the water pressure dramatically different than outside the cave?
Definitely not. It would be dangerous to find out the hard way.
The water pressure under your shelf is identical to the water pressure at the same depth, but not under the shelf.
Thanks. Why is that the case? Why wouldn't the shelf (or the cave) carry the pressure of the water above it (and if it were strong enough, not transfer the pressure to the water below it)?
To further elaborate on the question, if the shelf extended all the way across, so that it effectively cut the water tank in half, presumably the pressure at the bottom of the tank would be cut in half as well, right? Or not? But if I leave any space between the shelf and and the side, then the pressure at the top and bottom equalizes for some reason?
That sounds right intuitively, but I'm wondering about the math. Why does that happen if pressure is solely a function of the water weight above a given point?
Water pressure in triangular container
I'm trying to figure out whether water pressure is uniform across the bottom of a container shaped like a right triangle. Imagine that one of the shorter sides is the base, so there is a 90 degree angle on one side of the base and an acute angle on the other. Is the water pressure less in the corner with the acute angle than in the corner that is 90 degrees? The height of the water above the 90 degree corner is much greater than in the other corner, so is the water pressure greater in the 90 degree corner as a result? Or is there some principle that requires uniformity across the base?
[threads merged]
If water pressure were differrent at two points right next to each other, the water would have to flow from the high to the low pressure, wouldn't it?
Consider your house: is the air pressure much different inside than outside?
And see this link: http://hyperphysics.phy-astr.gsu.edu/hbase/pflu.html
Thanks Russ Watters.
Yes, I suppose it should flow from the high pressure to the low pressure zone, but if the water is in a closed container, there is nowhere for the water to flow. So, I assume the pressure just builds in the corner until equilibrium is reached. Is that the way it works? So that, in fact, water pressure is not simply a function of the weight of the water column above a given point? And, in the triangular container example, the water pressure would be the same across the entire base?
I thought about the air pressure in the house example as well. Does gas behave exactly the same way as fluid on this point?
Water is a fluid, and will transfer the pressure along with the water no matter if it has to go around corners or under shelves.
If i extend your shelf all the way across the tank and put a small hole in it, then the force of the pressure will "transfer" through that hole into the rest of the tank i believe. If i simply extended your shelf all the way across to cut the tank in half, and if the shelf were strong enough to take the water pressure above it without transferring it into the water below it, then at the bottom of the tank the pressure would be half of the normal pressure, since the shelf absorbs the weight of the water above it.
Edit: Also, remember that water pressure is putting pressure on something from all sides, not just from above or below or to the side. So standing underneath a shelf underwater wouldn't do you any good for the reasons I've mentioned above.
If it flows a few nanometers it will adjust the pressure distribution enough to equilize the pressure.
Well if a container is closed and applies its own pressure to the water, you just add the pressure added by the container.
Yes.
Gas is a fluid, so yes.
Depth related pressure is a function of density times height (assuming constant gravity force and density). The shape of a container and the actual amount of water or the weight of the water doesn't matter, only the height and density of the water. The pressure at the bottom of a 30 foot deep cylindrical tank is the same regardless if the tank has a radius of 1 inch or 1 mile.
  • · Replies 32 ·
13K
  • · Replies 26 ·
  • · Replies 56 ·
13K
