Doesnt information travel faster than light in case of black holes?
rahuljayanthb
hi,
i was wondering,
for a black hole, as everyone knows,the escape velocity is greater than light.
this means that the information about the existence of the black hole in terms of light never reaches the observer.
so if the black hole were the cease to exist at an instant of time, the observer will never see the event happening. He will only feel the instantaneous change in the gravitational field. so in a way both gravity and information has traveled faster than light.
an alternative way of considering the same problem would be by expressing gravitational force to be transferred by gravitons. in this case the gravitons reach the observer but the photons don't. so gravitons can escape the gravitational field or 'climb over' the curvature of space time while photons cannot.
so gravitons can be considered to travel faster than the escape velocity giving the same consequences as the first case.
where is my thought process incorrect?
None of this is possible or correct. Gravity does not travel instantaneous, that was the whole point of General Relativity.
so what is the explanation or correct thought process for this?
As far as what happens if a black hole were to all of a sudden cease existing, there is no explanation because that's not possible. There is something to be said about information that passes into a black hole though ( http://en.wikipedia.org/wiki/Information_loss_paradox ).
During black hole formation there is no instantaneous change in the gravitational field. Gravitational waves are generated during the collaps outside / before the formation of an event horizon. In perfectly symmetric collaps w/o gravitational radiation for an outside observer the gravitational field does not change at all, the Schwarzschild metric is stationary.
No. The Schwarzschild metric is stationary, and gravitational waves generated during the collaps outside / before the formation of an event horizon travel with v=c.
It's a common misconception to think that gravity is mediated solely by gravitational waves (gravitons - which we don't need b/c we do not quantize gravity here).
Compare that to electrodynamics and QED: there is a well-known and exact formulation of QED where by integrating out unphysical i.e. gauge degrees of freedom one finds a Hamiltonian consisting of
1) a stationary Coulomb potential for charge densities plus
2) fluctuations i.e. transversal photons.
So there is a stationary Coulomb potential which does not rely on any photon to be exchanged. In addition one can prove explicitly that this formulation is fully Lorentz covariant (even so the stationary Coulomb term looks strange; the algebra of all Lorentz generators closes w/o anomalies, showing manifest Lorentz covariance in the QED Hilbert space).
Something similar is known in gravity. If you look at the effective gravitational potential used for the calculation of perihelion precession it looks like an instantaneous Newtonian potential plus (instantaneous) correction terms; but of course there is no instantaneous interaction; the formulation does neither break symmetries of GR nor does it violate c a s universal upper bound for physical interactions.
As explained gravitons neither can not need 'climb over' the curvature of space time; the external gravitational field is not generated by gravitational waves leaving the black hole but is nothing else but the gravitationsl field that already existed before the collapse.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
