Doesn't relativity define time as an illusion?
  • Thread starter Thread starter zeromodz
    Relativity Time
zeromodz
Like everything is in 4 dimensions. The 3 spatial ones and time. The past, future and present are already determined and just waiting to happen. There is no flow of time. What are your opinions on time, and what about a block time universe? How can time not be a flow, don't you need time in between each snapshot?
An observer is a worldline in spacetime. Along his worldline, proper time, which is read by atomic clocks, passes. The difference from Newtonian time is that it is not universal, each observer has his own time.
To answer your question no. The four dimensional solid you talk about is a mathematical construct. Here in the physical world there only exists an infinitesimal thin sheet with three large dimensions (spacial) and one infinitesimal (time).
an interesting and deep question. Relativity does indeed force us to view the universe as a four-dimensional space-time manifold.
Thus, time apparently doesn't flow, it simply "is."
Whether you should now choose to describe time or the flow of time as an "illusion" is up for debate. Certainly psychologically the flow of time is certainly very tricky; we can be fooled. But should we describe the disconnect between the physical descriptions of time and our internal experiences as an Illusion? maybe.
It is thought that the possible physical bases of a "direction in time" may some day explain why we experience a forward flow. Current work relates to Entropy, information theory, as well as cosmological explanations.
I started reading a National Geographic article related to the Big Bang. It starts these statements: Gazing up at the stars at night, it’s easy to imagine that space goes on forever. But cosmologists know that the universe actually has limits. First, their best models indicate that space and time had a beginning, a subatomic point called a singularity. This point of intense heat and density rapidly ballooned outward. My first reaction was that this is a layman's approximation to...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
11K
