Python Doing Automatic Differentiation
The discussion centers on an interactive session utilizing the ODE Playground, a repository for Automatic Differentiation code. It demonstrates two methods for approximating the square root of 2: Newton's method and the bisection method. Users can input a function via a lambda expression without needing to specify step sizes or other numerical artifacts. The results show that Newton's method converges to approximately 1.414213562373095 after 7 iterations, while the bisection method yields a result of approximately 1.4142135623733338 after 38 iterations. The session also introduces dual numbers, showcasing their properties and operations, such as the calculation involving dual numbers 3.0, 5.0, and a variable dual number 7.0.
m4r35n357
This is a brief interactive session using my ODE Playground, which is my repository of Automatic Differentiation code. It illustrates two solutions of ##\sqrt {2}## with the user-specified function provided via a lambda, using Newton's method and then bisection. Note that the user needs to provide no step sizes or other requirements or artifacts of numerical differencing, just the function itself!
Python:
$ ipython3
Python 3.7.1 (default, Oct 22 2018, 11:21:55)
Type 'copyright', 'credits' or 'license' for more information
IPython 7.2.0 -- An enhanced Interactive Python. Type '?' for help.
In [1]: from ad import *
ad module loaded
In [2]: from playground import *
playground module loaded
In [3]: Newton(lambda x: (x**2), x0=1.0, target=2.0)
Out[3]: ResultType(count=7, sense='', mode='ROOT', x=1.414213562373095, f=2.0000000000000004, dx=-1.5700924586837747e-16)
In [4]: bisect(lambda x: (x**2), xa=1.4, xb=1.5, target=2.0)
Out[4]: ResultType(count=38, sense='', mode='ROOT', x=1.4142135623733338, f=2.0000000000006755, dx=7.276401703393276e-13)
Enjoy!
Likes jedishrfu and Dale
Technology news on Phys.org
OK here's some dual numbers:
Code:
$ ipython3
ad module loaded
In [2]: a = Dual.get(3.0)
In [3]: b = Dual.get(5.0)
In [4]: c = Dual.get(7.0, variable=True)
In [5]: print(a)
3.0 0.0
In [6]: print(b)
5.0 0.0
In [7]: print(c)
7.0 1.0
In [8]: print(c**2 - a * c)
28.0 11.0
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I have a quick questions. I am going through a book on C programming on my own. Afterwards, I plan to go through something call data structures and algorithms on my own also in C. I also need to learn C++, Matlab and for personal interest Haskell. For the two topic of data structures and algorithms, I understand there are standard ones across all programming languages. After learning it through C, what would be the biggest issue when trying to implement the same data...
